Question about Garden
I have never used a weedwacker and need help loading the string onto a homelite st40 electric weedeater that was given to me
#1 Taper
  • 1040 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
AUTODOC01
  • 216 Answers
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Posted on Aug 25, 2009
  • 474 Answers
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Posted on Dec 25, 2009
rycgl
  • 1545 Answers
SOURCE: I need owners manual for 25cc, 17" Craftsman
Go to www.searspartsdirect.com and have your model number ready.
Posted on Jun 12, 2010
How to put the housing back together on my homelite weedeater
Try this: https://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
May 13, 2017 | Homelite Garden
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Homelite weedwacker fuel oil ratio
Hi cjchris66,
Welcome to fixya!
The ones I looked at use 50:1
Copy and paste this web address into your browser: http://www.homelite.com/service_support/product_owners_manuals
Scroll down to the string trimmer section and find your model in the list. You can download the owner's manual and check out the ratio to be certain that your trimmer uses this ratio.
Please place a vote when you accept this solution. Thanks for visiting with us.
Handie Andie
Aug 22, 2011 | Garden
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Oil to gas ratio
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Apr 20, 2009 | Garden
Need manual for homelite sx-135 weedeater
http://www.homelite.com/service_support/order_parts
Feb 14, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
