Question about Dryers
Dryer makes a "thump thump" noise when tub is spinning. Dryer is balanced and not overloaded.Makes the same noise even when empty.
  • 64 Answers
SOUNDS LIKE THE ROLLERS FOR THE DRUM HAVE BROKEN DOWN , USALLY ITS JUST ONE BUT, I"D REPLACE THEM BOTH.
Posted on Sep 25, 2009
  • Dryers Master
  • 3,361 Answers
Replace the drum rollers on the rear of the drum.
Whirlpool type 111 washer drains won't spin. makes loud screeching noise. installed new clutch assembly. still no spin.still high pitched noise (like a belt slipping) but type 111 is direct drive
Belt slipping? is the wash tub free to turn when empty? socks and small clothing items may be jammed in the drum / tub cavity caused by overloading if its stuck. May need to strip machine and remove drum to get them out.
Don't overload machines!
Feb 03, 2018 | Whirlpool Washing Machines
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Dryer not spinning
it makes a humming noise..defective motor,,also you need to replace door switch...onthejob
Jan 10, 2009 | Kenmore 72802 Gas Dryer
The washing machine makes loud banging noises when its running.
Either the machine is not balancing correctly or something mechanical has broken. If it works fine when empty then it is a balancing issue. If it does this even when empty then something has broken that supports the tub.
Jan 07, 2009 | Washing Machines
Tub gets off balance and makes noise while washing.
It probably does this because you have overloaded the machine with towels or bedding try putting less in...
Jan 03, 2009 | Washing Machines
Kenmore washing machine shakes violently
There is the tub that spins on the bearing the " the active tub"(the one the clothes go in obviously) and around that tub is the "stationary tub", between the two are what they call "snubs" these are either rubber wheels, bushings or on cheaper models just a rubber boot that works as a shock absorber if you will, and keeps the movement of the the "active tub" with in its axis. If a wheel is broken, or a bushing/boot is torn or broken then there lies your problem.
I hope this helps.
Aug 06, 2008 | Washing Machines
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Dryers Logo
333 people viewed this question
Top Dryers Experts
