Question about Canon PIXMA MP750 All-In-One InkJet Printer
It just stop working I check the fuse and is ok but can't turn on
Change turn signal fuse on 2007 on bmw328i
check turn signal fuse if ok check turn signal flasher unit.
Aug 15, 2014 | 2007 BMW 3 Series 328i
2 out of 3 brake lights dont work
If any light lights up when you apply brakes, then the brake switch is ok. The problem could be a fuse and/or a relay. or the bulbs. Those bulbs are dual filament so one filament could be bad, for stop or tail lights.
Oct 02, 2012 | 2002 GMC Envoy XL
My break light fuse keeps blowing in my 97 suburban any ideas why
Assuming it's a K1500, 15A STOP/HAZ fuse 1 in the instrument panel fuse block is the source of power. If the stop lamp switch checks OK, and the center high mount stop lamp is OK, the cruise control system gets input at this point and may be defective. Fuse 1 also feeds power through the turn/hazard switch to the stop filaments of the tail/stop/turn lamps and these presumably are OK
Sep 22, 2012 | 1997 Chevrolet Suburban
All my turn signals stopped working on my 96 GMC Jimmy. Fuses are ok.
Check the flasher under the dash. They are around $10 at an auto parts store.
May 25, 2012 | 1994 Chevrolet S-10 Blazer
Turn signal stopped working and fuses have been replaced
Check your bulbs to see if they are working. If one is brunt is will stop the turn signal from working. If your bulbs are OK then check you flasher relay.
Dec 04, 2010 | 2005 Chevrolet Equinox
Both my turn signals and emergency flashers stopped working
hi...
there is a relay which connects turn indicator and the emergency flashers which is provided for the timing of the flash.this timer relay may got burnt or damaged. even though the fuses are OK the turn indicators wont work. please check this.
please rate me weather the information which i provided was usefukll to you by clicking on the thumbs present on the end of your page.thank you
Jul 09, 2010 | 1999 Ford F350 Regular Cab
Turn signals stopped working. Fuses are all ok,
sounds like the flasher can might have stopped working, you will need to get it replaced, it regulates the indicaters to blink, when it goes the circuit is gone, time for replacing id say. check the relays in the main fuse box under the bonnet first, try swapping the relay with another one like the horn relay just to test that first.
Jun 21, 2010 | 1999 Cadillac DeVille
Brake lights will not work turn signal works fuse is ok
if no brake lights are working,not even the high stop light in the rear window,And you have checked the brake lights fuse with a test light,it will be time to check the stop light switch located on brake pedal under dash.
Nov 26, 2009 | 1999 Chevrolet Lumina
Canon PIXMA MP750 All-In-One InkJet Printer Logo
old marine
old marine
