Question about Duravit 0910100005 Happy D Toilet Cistern - White
Water flows unneccessary from the cistern in the toilet; being wasted. How can I stop it? Can you give me some tips please.Thank you.
  • 129 Answers
All you need to do is replace the tank flapper.
Posted on Sep 26, 2009
Testimonial: "Thanks for the tip.Flapper was fine,than I noticed that the round rubber seal was getting stuck.Cheapest solution - petroleum jelly...as good as new!"
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
How do i adjust the toilet tank from over flowing
adjust the float setting or the setting on the unit around the inlet pipe
this is achieved by screwing up or down on the threaded section read the instructions as you may have to fit a pressure regulator before the cistern tap if utility pressure exceeds the desired operating pressure of the cistern
Nov 07, 2015 | Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Adjust water level in in-wall Italian toilet cistern
It could be your flushing mechanism inside the tank that is letting the water in even after the flush. First flush and watch the bottom mechanism whether it blocks completely when water is full in the tank at set level and no more water flows.
Jul 27, 2013 | Home
Toilet Cistern Sticking
Mechanism that releases and shuts off water should be checked if any part has disconnect or improper connection.
Jul 09, 2013 | Home
My daughter flushed he winter hat down the toilet. How do i get it out?
Kids eh?
.. I had my son flush LOTS of wipes down ours ...
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Feb 09, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Hi i'm pretty sure my son has just flushed a baby wipe down the toilet and now my saniflo is making strange noises and doesn't appear to be working properly, how can i check if the wipe has become tangled...
Hi, Had this myself with my son a while back!
Feb 08, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Duravit 0910100005 Happy D Toilet Cistern  - White Logo
1,429 people viewed this question
Top Duravit Home Experts
paulcarew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
