Question about Sony PlayStation 2 (PS2) Console
Ps2 screen display problem
I accidentally switch display to RGB but I want to use component! well now it doesnt display anything on my screen because its looking for RGB cables is the a default reset switch or something or is there someway to get it back to normal???
    Problem Solver:
  • 17 Answers
Try reset to the Default Configuration, Remove the Memory Card and try this:
Press the Power and turn off,
Press the Power and Turn on, without a MC the default has been charge.
- No have a "reset sequence" but I can send to you a sequence to reset rgb without video".
Sequence: when the ps2 sound "ready" press:Down, X, Down, Down, Down, X, Right, X.
After Default Load, in "Browser" put your memory card and delete a System Configuation for the MC, the icon is a PS2, and save a new configuration, Done, if the problem not solve, send me a mail or msn gamba.support@hotmail.com (Mail and MSN)
Posted on Dec 17, 2007
    New Friend:
Change your RGB wire Or the other wire and u can operate
Posted on May 07, 2013
Hook up with cables that came with PS2, then unselect RGB. I know this works, for I did what you did and this fixed it.
Posted on Apr 19, 2008
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
My tv displays "format not supported"
Too many variables with what you are describing here. How old is the TV and how old is the DVD player. Did you verify that the components were all plugged in to their corresponding colors....blue to blue, red to red, green to green. Is the RGB cable verified good. Another common mistake is to plug the video jacks into ex. VID 1 while the Audio is on VID 2. Make sure they are on the same numbered input and that the TV is on the input your jacks are in. The HDMI may not work because there are three different HDMI types and not all play well with each other. The problem can be fixed with an HDMI converter but gets into more cost. Eliminate above mentioned and repost. I would be glad to troubleshoot you through this.
Mar 12, 2014 | Sony DVP-SR500H DVD Player
I tried to hook my wii to the new hd led flat screen but its black and white I tried doing the yello cable to green but it doesnt work and all the other inputs dont have ac jacks its just hdmi hookups
The yellow cable is RCA component and it sould not be connected to the Green port. Why not get a HDMi cable to make the hook up easier? Component RGB connection requires a RGB cable along with a stereo audio cable where as HDMI requires just one.
Jun 10, 2011 | Nintendo Wii Console
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
Playstation does not start up
you have to use the conventional audio video jacks first. then access the options menu and enable the component video cable options. i think it will ask you what kind of format your tv supports, and after that, replace it with your components
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Sony PlayStation 2 (PS2) Console Logo
2,568 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
