Question about Lexmark X3470 All-In-One InkJet Printer
I need to know why my printer isnt taking in paper. And it keeps saying Printer Busy. What Do I Do? thank you..let me know please.
SOURCE: Paper jams
I had the same problem and fixed it by giving the printer a good cleaning and turning the paper pickup tires (under the front of the printer, above the tray) inside out (they were showing some wear).
Posted on Jan 17, 2008
  • 37 Answers
SOURCE: My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Posted on Apr 19, 2009
Roop1980
  • 228 Answers
SOURCE: won't print says its busy
You need to clean NVRAM on Lexmark X7550 printer. Please follow the steps given below:
1. Power "Off" the All-In-One.
2. Press and hold the number button and turn the All-In-One back on. Press and hold the "Color Start" button and the "Check" button at the same time and turn the printer ON.
3. Release both the buttons once the printer is ON.
3. Press "Down" arrow button to go to the "Maintenance" menu entry. Press "Check" button.
4. Press "Down" arrow button until you reach "Manufacturers Test." Press "Check" button.
5. Press "Down" arrow button until you reach "Clear NVRAM." Press the "Check" button. The printer will restart by itself.
6. You will be prompted to go through setup again and to print an alignment page.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance.“
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
jamielwright
  • 75 Answers
SOURCE: my lexmark C510 printer keeps saying short paper but it is full. What is going on?
You may have too much paper in it.Take some paper out and try it again.
Posted on Jun 01, 2009
SOURCE: no paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
I had a paper jam, removed paper and now when I attempt to print, I got mssage saying printer is busy
go into were it is saying printer is busy and cancel any work waiting to be printed..but before you do that unplug your printer the plug back in some times this will re,set your printer.
Nov 05, 2016 | PRINTER Office Equipment & Supplies
Message in the screen add paper
The best thing you can do is read the manual first, it explains all these things. Just in case: That is telling you to put more paper in or it will quit printing. Try these links:
Canon printer says its out of paper when there is paper
The printer keeps saying its out of paper and its not not sure if paper is... My printer says paper is jammed when it isnt HP Printer keeps saying to add paper but it in
May 30, 2016 | Office Equipment & Supplies
Printer says there is a paper jam but there isn't
Please insure that the paper sensor flag is still in it position. Open the printer and look about in the middle to see the flag. Feel if it moves freely.
Mar 14, 2012 | HP Office Equipment & Supplies
My printer wont take the paper, keeps saying its out of paper when there is a full tray
I have tried to copy a photo on my HP C4600 printer, I put photo under lid in correct place and inserted paper in the correct way yet printer screen keeps coming up paper empty ? what should I do please ? thank you
Aug 10, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer busy cuz scanning nothing
hold power button in for 5 secounds and let go then turn back on and say prayer no mroe paper flys out. might clear its bug.
Dec 01, 2009 | HP PhotoSmart C4280 Laser Printer
My printer keeps saying busy but all my print jobs that were in que I have deleted and there is nothing waiting to print. I just put in new cartridge and I cant align until it isnt busy anymore.
You might need to simply reset it. See this article for help. Also see this article. And your home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 10, 2009 | HP PSC 2175 All-In-One InkJet Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
Lexmark X3470 All-In-One InkJet Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
