E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise. If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one. 120V: FH3-2613 220V/240V: FH3-2614 The circuit has been modified to resist a noise.
REMEDY
Caution Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
haveing problem with ben q projector- when you turn it on the ben q logo comes on then the picture...
(More)
haveing problem with ben q projector- when you turn it on the ben q logo comes on then the picture comes on the fans start running, a little louder the normal the the picture shuts off, the 2 red lights on the projector starts to flash you then only have sound
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer...
(More)
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer through the network. Any suggestions on how to configure the copier/fax/printer to allow access / verify that access is available?
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix...
(More)
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix this?
