Question about Toshiba 50H82 50" Rear Projection Television
Red convergence is out on the TV. Use the touch
Red convergence is out on the TV. Use the touch focus and then tried the other way and neither worked.
  • Toshiba Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
MikeNJ1964
  • 398 Answers
SOURCE: Toshiba 42H81 Rear projection "Convergence problem"
One of your convergence IC's has burned out and needs to be replaced. A good rule here is to go ahead and replace both STK392-110 IC's with the new improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits, allow a qualified tech to handle it for you.
Posted on Aug 14, 2007
  • 4 Answers
SOURCE: convergence problem
Replace the Convergence amplifiers. Mine did the same. It was like watching a 3D movie without the glasses. It is not hard to do for someone who knows their way around a circuit board repair. Otherwise call a reputable service shop.
Posted on Jul 10, 2008
  • 6 Answers
SOURCE: Red is out of convergence
These sets use STK392-110 voltage amplifiers in the convergence circuit. Chances are good that these are causing your problem. It is best to upgrade these to STK392-150. There may also be some low tolerance resistors that have gone off value. I do not suggest, however, that you do this work yourself unless you have some electronics training. Find yourself a good technician that does component level repair and not board level. The labor will be higher, but the parts will be significantly lower.
Posted on Aug 26, 2008
  • 166 Answers
SOURCE: convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Posted on Nov 26, 2008
SD Tech
  • 14553 Answers
SOURCE: the convergence is off. When I try to use touch
Ok, we go to solution of your problem===The pico fuses are green and on the main power board--have you removed the back and looked inside--most of these sets have the two STK-392-110 on the main board to the right-they are usually on the left edge of this board on two very large metal heat sinks--chips are about 2 1/2 inch wide X 1 1/2 inch tall--is this how your set looks inside? they will have the number printed on the black face of each chip in white--The fluke meter will allow you to check all the grey protect resistors--most are 1.8 ohm and the pico fuses will be near the edge of the board to the left----All I expect from you for help is a vote here--if you remove the back do you see the chips?
Posted on Sep 19, 2009
Testimonial: "I am delighted with this site and the people that are accociated with it. It amazes me, the level of expertise and the willingness to help someone. "
My toshiba 57h81 tv is showing up double vision, looking like the red is off and not aligned. Also the touch focus in the menu says error whenever i try to touch focus it.
This tv have a problems known as a Convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.This parts must be replaced to solved the convergence board problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Toshiba 57H81 57" Rear Projection...
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
The touch focus on my 50h81 says touch focus error, the red vertical is crooked. There is a red and touquoise line surrounding everything on the picture.
Ur convergence is dead.U must know how to solders?Must replaced 2 convergence ICS,and some or all the resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300 for parts,and labors.
Mar 15, 2010 | Toshiba 50H81 50" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
When the TV is on, on the outlines of people and text are in Red and Green lines. I have tried the touch focus and it is not working. it is saying that there is a "touch focus error" can I manually adjust...
you need 2 new convergence chips, part number stk 392-110, also check for burnt up resistors next to the chips, major disassembly and soldering, you probably need a tv repairman.
Sep 24, 2009 | Toshiba 42H81 42" Rear Projection...
You can repair it yourself by replacing both STK392-110 Convergence ICs. You can get replacement ICs at the following link with free instalation instructions . Heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | Toshiba 65HDX82 65" Rear Projection...
Aug 05, 2008 | Toshiba 50HDX82 50" Rear Projection...
Convergence problem
Jun 17, 2008 | Toshiba 50H81 50" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Convergence problem
sounds like bad solder connections on convergance ic solder then if the problem still there replac ic
Oct 24, 2006 | Toshiba 57HX81 57" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
