Question about Fedders Y Chassis AEY12F7E Air Conditioner
E-3 code air conditioner will not run.
E-3 code . the a/c will not run..
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
HOW TO RESET A CODE ON A SAMSUNG SMART INVERTER MODEL NO AQV24uwbn?
Unplug it, then plug it back in. Unless you repair the cause of the error code, the unit will fault out every time it sees the error. It is basically saving its own life.
Feb 23, 2015 | Samsung Heating & Cooling
E3 error code
e3 error code comes when room not getting cool after 3 hours ac working, pls close all doors and windows and if possible try to run ac in an empty room for 1 hour , then check for fault,
Oct 13, 2013 | Kenwood KW85 Air Conditioner
MODELNO 42SD6B SERIAL NO 3103Y90080 PROBLEM ER13.NOT WORKING SHUTDOW PLEASE INFORM WHAT IS THE PROBLEMS
Carrier make model no is 42SD6B the problwm is when the unit is running it run's for only 4 min then it's shuttdown give the error code 3 after 3 min. it's starting automitcally again it trip after 4min giving the error code 3.
So I just want to know what is this code stand for, what precaution should I take to solve this problem.
Oct 15, 2010 | Carrier 38CKC036 Air Conditioner
Eo error code indoor unit runs 2-3 seconds then gives eo error code problem started when mr chipmunk chewed mr slims 12 volt wire connecting to out door unit and shorted it . Outdoor unit has bad control...
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Jul 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
Aug 05, 2009 | Fujitsu 18C1 Air Conditioner
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Fedders Y Chassis AEY12F7E Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
