Question about Maytag MAV7357AW Top Load Washer
Will not start at all! It has power and it's getting water to it.
Buy a new unit
Posted on Sep 25, 2009
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
Tip
How to install a Water heater
Step one removal of the old one start's with turning the power source and water off to the water heater.
Once power and water is off connect a water hose to the drain on bottom of water heater to start draining. Open the drain and the hot side to a faucet to help water drain quicker.
Once drained and new heater their to go back in. Remove old one and reinstall new one.
Connect wires and water lines to new heater and turn water on first to heater once everything is connected.
Let water run til you get all the air out of tank and water running from hot side on all faucet's throughout house before turning power on to heater.
Once all air is out of tank and water flowing from all faucet's you can turn power on to new heater and about 30 to 40 minutes you should have hot water.
on Jul 13, 2010 | Plumbing
My Hfdw80 dishwasher wont start.There is a motor winding noise but no water?Hotpoint
Hi First you have to check the water valve to see if it has power during the time it should be filling the washer , Set the unit to fill and wash you know where it normally starts filling with water , remove the two wires from the water valve and check to see if you have power going to the valve , you have to eleminate things to find out what the problem is , if you have power then check to see if you have water to the valve, if you have water and you have power but you arent getting water then the water valve is bad , and this will be a cheep easy fix , have a good day
Nov 24, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Pumps water out but not water in to start cycle
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 07, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Water doesn't get cold anymore.
Hi, check receptacle for power, plug something, fan, radio etc, if there're power (voltage) it's possible your compressor has hard start, you can buy compressor hard start kit and try to start compressor, if compressor are working, maybe you got, freon leak, or you could have low voltage problem, or faulty overload relay on compressor, unplug water cooler, for about an hour, then replug it, let me know what happened, then i can tell you exactly what's problem. good luck.
Aug 11, 2009 | Hamilton Beach Water Cooler with Storage...
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
Power point dishwasher - not washing dishes
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | Dishwashers
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and filter and everything was ok, but the water still would not come into the machine. I than check the...
As the solenoid should should remain power free and closed until the programmer tells the circuit board to switch on the power, it could conceivably be either or both of those things, though I feel the chances are greater the circuit board is at fault.
Apr 05, 2017 | Asko W6661 Front Load Washer
No water
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Jul 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAV7357AW Top Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
