HP dv9200 not charging battery
I have an HP dv9200, which I had to open up to replace a faulty audio board on. The installation and reassembly went fine, but ever since then, my battery has not been charging. It is detected by the computer, but simply remains at 0% with ''Plugged in, not charging'' as its description. I have also tried a brand new battery in the laptop, but the result was the same.
  • nmccrack37 Sep 27, 2009
    I opened the laptop up again, and check the connection running from the AC plate to the motherboard (I only saw the one), and made sure it was properly seated, but no luck. Running the HP Battery Check says that no battery can be recognized, so the computer doesn't seem to see it. The blue "charging" light on the front of the laptop is continuously flashing, but I cannot remember what this means under normal circumstances. Any other ideas?
  • nmccrack37 Sep 29, 2009
    Additionally, I "talked" with HP customer support. They suspected it might be an issue with the "motherboard power supply". I questioned them if this meant the CMOS battery, but they were unable to tell me. Could the CMOS battery be at fault for this issue?
  • 909 Answers
You may have loosened a connection by mistake or connected a wire wrong. open up and check all power connections.
Posted on Sep 26, 2009
  • Paul Hutchinson Sep 29, 2009
    the cmos battery keeps the date/time settings in the cmos memory chip as well as certain boot and bios settings.
    the first sign of the cmos battery failing will be the date time reset to factory setting. (if the chip was set at 1/1/2005 at 12:00 the date/time will come up as that every time you boot up)
    Can you check the charger on another laptop? or using a test meter?
    President:
  • 2,600 Answers
There are two cables that come off the DC jack plate and plug into the motherboard. Make sure that you seated both these cables fully or you will have the above problem.
Posted on Sep 25, 2009
Hello, I have a Marquette Mac 6. recently the battery went dead and we just replaced it. but now after replacing it still says the battery is 0/50. I went through the instruction manual and followed all...
hi,
You have to chek the battery charging circuit of your Mac 1200. If the the charging circuit is faulty then the battery will not get charged. In all ecg machines AC line is used only for charging the batteries . Even though if you are connected the AC line the machine will work on battery. It uses a 18V 1.4Ah battery. To get this battery to full charge it need a charging voltage up to 20 to 21.5 volts. Connect the machine to the line and check the votage at the battery terminal. The volatge should gradually increase. If not then the charging circuit is faulty. You have to check the Inductor coil L3 and Thermistor R5 in the charging circuit board after removing the battery and power line.It shouid show an OHMS bellow 5 OHMS. Also you have to check the 24V input to the charging circuit from the power supply.
ok
Aug 10, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
My son had a liquid spill on his ds lite and the top screen went blank. Following troubleshooting advice, I dried out the battery etc and reassembled it. It has been working ok for 12 hours approx but now...
This happened because residual of water, or consequential oxide on wiring or board contacts caused a short inside device.
Try drying again, if it still does not work, one of the components has blown, you will probably need to replace the internal board.
Check for oxide on connectors.
Sep 02, 2008 | Nintendo Video Game Consoles & Games
Comp went off with the battery lights blinking and doesnt charge
Sounds like your wall supply is gone bad, you must check to see, remove battery, an use only wall supply, if it doesn't go, it is that. if it does, then your battery has gone faulty.
Mar 30, 2010 | HP Compaq nx6110 Notebook
Replacing hp dv9700 keyboard
Look for the screw marked with a keyboard icon and removed them then you should be able to remove and replace the keyboard. Not too hard. You can get the service manual from HP if needed.
Mar 09, 2010 | HP Laptop Keyboard for HP Compaq Pavilion...
I just installed a replacement motherboard on an HP dv9000. I was having a video issue. That is now fixed, however, now my battery won't charge and I have no sound. I reset the connections and reset the...
Your right. The motherboard that is installed to your laptop is faulty with some hardware like sound and a power. Better to check it again from the one who replaces the motherboard and with all of your devices to be working okay.
Oct 15, 2009 | HP Pavilion dv9000z Notebook
there could be a few problems but first off does it run on just the battery or does it always need power? if it always needs power then id take the covers off the bottom of the laptop and check the wires from the conector on the back of the laptop to the battery, and also try giving the pins where the laptop and battery conect the amount of times iv stripped a laptop down and found its a dirty pin is anoying
Sep 25, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My iPAQ 5555 won't charge.
well that's really the problem when u go ur phone stocked for a weeks or two. i have my advice.. try charging yout battery manually. how is that? modification is needed. remove your battery from ur phone. and connect it to your charger directly.. (how is that? create a wire that can connect your charger to your battery. make sure u connect the right polarity) in this way your battery will charge for a moment and will give enough power to turn on your phone. because showing up that orange thing when charging up needs an initial power. so that is why. but still u can charge your phone. just live it maybe for an hour. it may work!
Aug 16, 2009 | HP iPAQ H5555 Pocket PC
How to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Nov 20, 2008 | Braun Syncro 7526 Electric Shaver
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
