Question about Refrigerators
MY JEN-AIR fridge/freezer will not cool and temp. keeps rising
  • 2 more comments
  • Anthony Dawson
    Anthony Dawson Sep 25, 2009
    It has been 12 hours since the temp. started to rise for no apparent reason.
  • Anthony Dawson
    Is there anything i can try to fix this problem
  • Anthony Dawson
    It's both the fridge/freezer not working and the motor is running.
  • Anthony Dawson
    Anthony Dawson Sep 26, 2009
    THE PROBLEM IS NOT RESOLVED
    President:
  • 497 Answers
A number of things need to be checked out, it would help to have a bit more info.
Have you checked/replaced the thermostat?
Is the motor running?
Whens the last time you checked the Condenser unit?
Is the problem only in the fridge? or just the freezer? or both?
Posted on Sep 25, 2009
  • Greg Mills Sep 25, 2009
    How hot is the temp? and is the condenser unit running?
  • Greg Mills Sep 26, 2009
    Sir, im trying to help you out, but your not answering my questions and you are being very vague about the info. And it doesnt help that it's taken you over 6 hours to respond when i leave a comment. Im trying to help, but you need to give me more info.
    Guru:
  • 1,326 Answers
A couple of things, either the refrigerant is low and needs to be recharged or the compressor has gone bad. It needs to be checked by an HVAC person..
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator wont cool
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Feb 01, 2010 | Refrigerators
Jen-air refrigerator noting cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2009 | Jenn-Air JCD2389G Side by Side...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
