Question about Draytek Vigor2800V Router
How do I reboot my router a Draytek 2800 remotely?
How to config vlan on switch 3cdsg8 and a router draytek 2920
You can configure trunks TRUNKS > Configuratio
n.
You can configure port to be part of that truck via TRUNKS > Members
Jun 16, 2014 | Draytek Computers & Internet
Unable to establish wifi for windows 8 to draytek 2390vn
I have the exact same problem. I end up with limited connection. Same machine on Linux connects to the same network without any problem.
Feb 11, 2013 | Draytek Vigor 2930Vn Wireless N Router...
2930Vn firmware upgrade
Download Zip file and extract. Then use the Firmware Upgrade Utility. It should be installed on PC
http://www.draytek.com/user/PdInfoDetail.php?Id=39#PdQuLinkInfo
Step by step procedures are explained in PDF User's Guide.
Nov 02, 2012 | Draytek Vigor 2930Vn Wireless N Router...
Logmein works slowly through draytek router
Check that you have the latest firmware for the router and the latest drivers for the PC. Take a look at the tech support for logmein as well.
Sep 11, 2012 | Draytek Computers & Internet
How can i set up my router?
The Draytek Vigor router supports USB-based Wide Area Network, or WAN, modems. It has four 10/100 Base-T ports, Network Address Translation IP packet filtering firewall, Demilitarized Zone and Virtual Private Network. The initial setup requires installing the firmware. Then, connect the USB router to the modem, in order to upload the firmware automatically to the modem.
Mar 07, 2012 | Draytek Vigor 2600VG Wireless Router...
Hi Team, I have a Draytek Vigor 2700 Router. I have redirected ports 80 , and 34599 to view my DVR cameras at my office. I have a static IP and i can successfully log into my DVR via HTTP port 80,...
It is an issue the Draytek and your phone.
Draytek displays as a web page. It uses HTML or XHTML
In order to see it on your phone it needs to be coded in XHTML Mobile 1.0
Jul 02, 2011 | Draytek Vigor 2700 Adsl2/2+ Router 2 Vpn /...
MY Draytek router V2900vg is not going back to Factory reset. Printer light keeps flashing (nothing connected) no wireless or LAN activity taking place.. Please help
According to this, http://www.bartek.com.tw/product/vigor/2900/doc/manual/ch20_reboot%20system.pdf
you restore the router to factory configuration in the reboot menu. One option is to reboot with the current config and another option is to reboot with the factory configuration.
If this does not work for you regarding getting the router back to factory config I'd call or e-mail Draytek. They have a good rep - high quality products and service at a higher price, so try them directly. When a factory restore does not work, only the manufacturer is left in a lot of cases, unless there are unbricking procedures,
Jan 09, 2010 | Dell Computers & Internet
NEED TO BUY A WIFLYER WIRELESS ACCESS POINT
an apple airport extreme , a netgear wireless g router or Pre N or a linksys G wireless router or Pre N router ( depending on how much you have to spend )
Also draytek are very good but pricey ( maybe check ebay for a draytek )
May 14, 2009 | WiFlyer WDB20B 802.11g/b Wireless Adapter
Draytek Vigor2800V Router Logo
222 people viewed this question
Top Draytek Computers & Internet Experts
David Payne
David Payne
Are you a Draytek Computer and Internet Expert? Answer questions, earn points and help others
