Question about Apple iPod nano
It is fully charged and even when plugged into pc wont switch on?
    President:
  • 392 Answers
Try restoring it...here's how 1.flick the hold switch on and off a couple of times. 2.press and hold menu and center buttons together until an apple logo appears on screen. 3.Once the apple logo appears and it goes  to disk mode,connect to system. 4.itunes should detect it in recovery mode.Use the restore option to restore your player.
Posted on Sep 26, 2009
WILL NOT SWITCH ON. BATTERY okay, CHARGES OKAY
If your computer recognizes it when its connected to the PC then you may have luck reinstalling the firmware.
If not, the unit maybe dead.
Feb 12, 2014 | Tablets & eReaders
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
What are the advantages and disadvantages of using a plugged in Gateway laptop even if it is fully charged.
If you use your laptop plugged in while fully charged it will shorten the life of your battery so that after a few months of doing this the battery will only hold the charge for a short time.
If you need to use it plugged in when the battery is fully charged it's best to remove the battery first.
Aug 27, 2010 | Gateway Computers & Internet
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
My laptop wont charge of swith on toshiba laptop brand new
If you have another power charger try it. It can only be one of two things. Bad charger or bad battery. Most likely the battery will need replaced
Aug 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Camera does not switch on, even though new batteries have been put in it
Is the new battery fully charged?
You mean no lights at all even a quick blink on any other light when you switch it on?
Did you plug the battery in correct way? (I guess it wont fit if its the other way around :-) but there are batteries that doesn't have keyway and they fit exactly even if they are plugged in incorrectly meaning their connectors doesn't reach)
Contact the vendor or manufacturer of your camera if its still under warranty.
May 05, 2008 | Cameras
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
