Question about Chase-Durer Bomber Command CD119.9JJX.BR09 Wrist Watch
The second hand stop moving but the watch is still working? how do i get the second hand to move?
  • Chase-Durer Master
  • 5,568 Answers
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
Posted on Sep 25, 2009
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
SOURCE: second hand moves every 4 seconds
Change the battery, regulary the increments is a way to let you know battery is running low, at least in swiss army...
Posted on Feb 14, 2011
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Posted on Oct 20, 2007
SOURCE: the second hand is not moving
Are you sure the big second hand is not used for the chronograph? I once had a watch that did exactly that. There was a small second hand in the lower left which was the normal secondhand, while the big second hand was used only for the chronograph. It annoyed the cr*p out of me, so I always had the chronograph running, just so the second hand would move.
Posted on May 24, 2008
escapement
  • 2334 Answers
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Yes, pulling out crown prolongs battery life, but this is only for allmost unnoticeable period of time.
With the seconds hand there are only one solution- you have to take your watch to the nearest watchmaker as you will not be able to deal with it without appropriate knowledge and skills.
There can be two reasons why the seconds hand is jumping:
1) Fault within integrated circuit ( watch 'brain' is not giving an impulse in a specific period of time),
2) Few teeth may be damaged on second wheel as well as there can be tiny dirt particles sticking onto it.
Both need attention of professional.
If that seconds hand do not annoy you too much, wait till the watch needs battery replacement and then replace battery and check the watch at once. It will be cheaper then to do both jobs separately.
Posted on Dec 20, 2008
Second hand is stopped, hour hand moves in oposite direction, behaves like second hand.
Peet you need to take it to an expert to fix this problem. The watch is complex. save it.
Dec 08, 2013 | Casio Edifice Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Second hand sticks to minute hand diesel dz 4021 watch
Likely the two hands are touching. A watchmaker can adjust them, shouldn't cost much,
Oct 04, 2012 | Zenith Watches 03-1260-4021-02-C505 Watch
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Second hand doesnt move. The ''stop watch'' second hand moves instead of the ''main'' second hand. also the stopwatch feature doesn't work. My watch is a Fossil Blue Titanium model TI-5071
Sounds like a job for Fossil!
Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
Feb 24, 2010 | Watches
Seconds hand stops moving
1st reason. This means your oscillating weight and paired gears are not generating enough power to charge capacitor, thus not be able to move hand properly. 2nd reason. Capacitor can not recharge itself to full power and needs to be replaced. 3 reason. Seconds or chrono wheel has a mechanical fault developed over the time and needs to be cleaned or replaced. Those are 3 reasons why the seconds hand stops moving in Kinetic watch. Which one is right, you will find out only after visiting watch repair shop, because I can not give correct estimate without seeing the watch myself.
Rate me, plz.
Jan 11, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
The second hand is not moving
Got the same problem guys. i have one of the new electronic diving eco drives.
First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Chase-Durer Bomber Command CD119.9JJX.BR09 Wrist Watch Logo
3,901 people viewed this question
Top Chase-Durer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Chase-Durer Watch Expert? Answer questions, earn points and help others
