Question about Linksys Wireless-G Broadband Router
Need to remove block from Linsys Router.
Need to remove block from Lingsys wireless Router.
  • 3,287 Answers
If you prefer model specific, exact instructions for your particular router, go to:
http://www.linksysbycisco.com/US/en/support
Provide the model, version etc. and follow links to the type of info you need.
If you need only generic directions, you can follow these. Since there are many different flavors of Linsys Wireless Routers, there are variations on how to get access to the places below.
Open a browser on a computer that has a wired connection to the router. This may be http://192.168.0.1, 192.168.1.1 or even 192.168.2.1 if left at the factory default settings. If you changed the default or can't get in a reset * may be needed. See the caution about reset below before attempting.
When connecting, you'll be asked for your username and password. If left at the factory setting, the username is blank password is "admin", of course, if you changed it - enter the proper values.
Look for the Wireless or Wireless Security Tab. The info needed to connect wirelessly consists of:
1) SSID (This is the "name" of your network or network ID)
2) Encryption Type (WEP, WPA, etc.)
3) Encryption Key (This is a combination of numbers 0 - 9 and letters A - F that you choose or are generated by a phrase of your choosing)
All the information for these variables that are stored in the router *must* be set exactly in the notebook wireless properties, otherwise it will not connect. If the SSID is set to "Do not broadcast SSID", it may help to enable SSID broadcast so that the network can be detected. Only when the network is detected, you will automatically be prompted to provide the encryption information. After the connection is made, you can set the SSID back to "Do not broadcast SSID" if desired.
* If the reset button on the router must be pressed, note the connection type on the setup page of the router. Copy any username, password and ISP data first.
Posted on Sep 25, 2009
How do i find the code for linksys wireless g broadband router
steve130823
The link below will help you look up the wireless WEP key on your router. Note most of the interface screens on all the Linsys models.
http://www.fixya.com/support/r6043023-setup_wep_wireless_g_broadband_router
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 13, 2010 | Linksys Wireless-G Broadband Router
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
About a week ago my HP Pavilion DV4000 couldn't pick up my wireless linsys G router and said that no wireless connections were found. I had to use a wireless B card I had lying around but still having...
You are using a B wireless adater on windows XP computer.
Tere might be adapter utility installed on your computer. You can use that software to connect to the wireless network or you can switch over to windows software to connect.
It will be better if you use the WINDOWS XP to connect to the network.
Check the wireless settings of the router also.
Click here for more information
May 03, 2010 | Linksys Wireless-G WRT54G Router
In router set up disc I wasn't asked for an ssid. Roku requires it. On the disc for the router, It also says configuration error and stops. What have I done wrong?
For configuration of Linsys Router the disc is not require, you can configure your router through internet explorer.
1. Set you computer TCP / IP on obtain automatic.
2. Connect your Computer to your router through Ethernet cable or wireless also.
3. and in internet explorer http:\\192.168.1.1
Username and Password "admin"
Mar 31, 2010 | Linksys Wireless-G WRT54G Router
My desktop is connected to my linsys, but I can't
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Mar 22, 2010 | Linksys WRT160N Wireless Router
Connecting Linsys wireless off of 604...needs 192.168.1.* to operate...can I create this as a static IP
yes you can to do this first connect with network cable to pc enter the ip adres and log in on the router ther in the menu you can change the ip adres thad you need dont forget to save befor closing otherwise the old ip adres stays
Dec 20, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
I can not connect my play station 3 to my linksys wireless g broad band router.
all network setting correct on playstation? try there support site www.linsys.com it is actually very good. Try wired or new wire if using wireless. this is a very finicky router. I have had to spend many hours playing around and reading. mine was the mtu setting was to low. set to 1492 and I changed to like....1600.
hope I helped, let me know
Nov 14, 2009 | Linksys WRT160N Wireless Router
Compatibility with imac
If you're concern about the price you can get the WRT54G since all router will work with any operating system.
May 16, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G Broadband Router Logo
117 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
