Question about Kirby G5 Bagged Upright Vacuum
My kirby just stopped working for no apparent reason. Everything seems in order but it won't switch on. I changed the fuse but this wasn't the cause. Any ideas why it isn't working?
    Problem Solver:
  • 33 Answers
It has a plug that attach's to the vacume itself , then that attach's to the wall, check that, try different outlets
Posted on Sep 28, 2009
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Intemitant power
DO NOT TURN ON THE KIRBY ANYMORE UNTIL YOU GET THIS FIXED!!! (not even to show someone what it sounds like)
Your carbon brushes are worn out and will cause damage to the armature if you run the machine before they are replaced..
You can use my guide for replacing the power switch to break the Kirby down and allow you to get to the carbon brushes to replace them.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Jun 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 stopped working
maybe the impeller broke, that is the most common reason for '' loud noise''....then you must remember that the kiby will not switch on [ all G models ] if the bag and the front nozzle is not properly attached.....
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuum stopped working
Sometimes after years of use the power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the switch may be bad or the motor needs to be serviced. Good luck. Please rate me so I know if I helped.
Dec 30, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby model gd3
The "switch" refered to is probably the handle release button.
Sep 07, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How to replace a fuse a Kirby Ultimate G Series
There is no fuse in the Kirby. There are few things that you want to check:
1. Cord - most likely cause. It may not be damaged but wires inside may have snapped if it got between doors.
2. Safety switch inside - no easy way to check. We usually just put a new one in and see if it solves the problem.
3. Motor - very unlikely that something is wrong with the motor - those are very hard to kill.
Apr 20, 2008 | Kirby Heritage II Vacuum
Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Apr 13, 2008 | Kirby Heritage II Vacuum
Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
Nov 07, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
237 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
