RCA Colortrack TV can't connect to a DVD
Our Tv works well but we have a combination VCR and DVD connected to it and all of a sudden the DVD quit working. VCR still works well.
The purchased another DVD and it doesn't work connected with the old VCR or just connecting the DVD directly to the TV. It is like the DVD hookup is blocked or turned off. Is that possible or do you have any idea why we can't have both a VCR and a DVD or even a DVD alone work on this TV.
The new DVD that we are trying is a RCA DRC190N and the screen just displays the word root. I believe our problem is a TV problem not a DVD problem.
Thanks
Laurel Penn
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
tvtek
  • 1284 Answers
SOURCE: Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2103095&cp=&sr=1&origkw=rf+modulator&kw=rf+modulator&parentPage=search
Posted on Dec 01, 2007
  • 135 Answers
SOURCE: Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Posted on Mar 24, 2008
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
leethedeuce
  • 4472 Answers
SOURCE: Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Posted on Sep 14, 2008
Will a dvd player work with a Panasonic PV-M2023 combo TV VCR, built in 1993? We connected a DVD player but haven't been able to get it to work. We have the original remote control.
I see that it does have RCA input (Yellow, white, red) on the reverse of the TV. Connect the DVD via RCA cable to the corresponding color connection, place the TV in "Vido" or "aux" mode. this is usually done on the remote from an "input" button, or it can also be called "game," "video," or "aux."
Upon putting it to this after connection of the DVD player, you should see the DVD players home screen. You should be set to enjoy the DVD player.
Jun 28, 2011 | Panasonic Televison & Video
Trying to connect vcr/dvd to tv. Do not have
you need to have your basic rca cables (yellow, red and white). The cables you are referring to are composite cables and if you do not have component inputs on your tv they will be useless. You can use rca cables on any tv that has video.
May 15, 2010 | Televison & Video
Have directv what are the connections i need
You should be able to connect direct tv OUT yellow red and white to the IN yellow red and white on your DVD player/VCR combination. Then you connect OUT on your DVD player/VCR combination to the av video input of your television. By yellow red and white I am reffering to composite/RCA cables. There might be a way to connect with component cables though. I would need more information.
Apr 28, 2010 | Televison & Video
DVD and VCR recorder with this product?
As long as you have Composite/SVHS Video Input, Usually a Yellow RCA Socket or a 4 pin Mini-DIN & red & White, AV (Audio Visual) RCA sockets on the machine, AND you can select an "External" input, then YES anything that can connect with this way will work.
Feb 10, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Jul 26, 2008 | Samsung TX-T3093WH TV
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
DVD SETUP
hi try these Code For Model RCR450 (the closest i found) Code 1000/3160/2000 for RCA TV/VCR/DVD Code 1000/3408/2000 for RCA TV/VCR/DVD http://www.rca.com/customerservice good luck windman
Dec 19, 2005 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
