Question about HP Digital Sender 9250c scanner Printer
Our hp 9250c scanner suddenly scans very light
    President:
  • 1,653 Answers
Reset the Darkness and use the setting to adjust the lightness or darkness of the output. Check the setting on the scan application as well as the 9250C.
Also check the document type and resolution settings.
If there is nothing strange about any of the settings then run the Calibrate Scanner function. If that does not cure the problem then you may have an issue with the quality of the lamp output or the scan detector and will need a service engineer to visit and rectify.
Posted on Sep 25, 2009
How to remove black ink from a document
Can I set my HP Digital Sender 9250C scanner to scan to my C drive via USB?
Nov 18, 2013 | HP Digital Sender 9250c scanner Printer
Digital sender 9250c is sending empty attachment
If it is sending an empty attachment, it means that the document that you are trying to send is not being scanned by the Printer. There are many reasons for this, one could be that the drivers need to be installed or reinstalled another is that it may need a service. In other words it may need some technical attention. The equipment within your scanner may be dirty, from time and/or use. First try installing the drivers, if it still doesn't work then try installing it on a friends computer/laptop. As a last resort, i would take it in for repair/service.
All the best!
damnor01
Dec 14, 2010 | HP Digital Sender 9250c scanner Printer
Our hp 9250c scanner suddenly scans very light The lightness and darkness settings have already been reset but it still scans very light
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP Digital Sender 9250c scanner Printer
I ahve a HP 9250c scanner, and my computer doesn't recognize it from the usb cable. It says it's missing IEEE 1284.4 printersupport. What can i do to fix this ? I have already installed all the...
It sometimes happens because of the USB cable. try it out with a different usb cable. Don't try it out with Chinese made usb cable because at times computers fails to detect a new hardware or gives error. As I had faced similar problem.
Aug 04, 2010 | HP Digital Sender 9250c scanner Printer
Our scanner says check supplies and will not scan. What does this mean?
Make sure you have a network connection and can ping the unit. Had one today that only shown Check Supplies and Administration. Found loose patch cable and then Email option appeared.
Feb 08, 2010 | HP Digital Sender 9250c scanner Printer
After scanning and emailing a document there is a red line on the emailed pdf
http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1217180
Oct 30, 2009 | HP Digital Sender 9250c scanner Printer
HP Digital Sender 9250C Color Scan Problem
We purchased 2 HP scanners 9250C and have the same issue. Send it back to HP, they make some correction for firmware, after 1 day, everything is ok.
Dec 06, 2007 | HP Digital Sender 9250c scanner Printer
HP Digital Sender 9250c scanner Printer Logo
739 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
