Question about Samsung CLX-2160N All-In-One Printer
Printer won't print. I get the message that the paper tray is empty when its not empty?? This started after I loaded paper in the tray the last time. Removing the tray & putting it back doesn't work. Resetting the printer by turning it off & on again doesn't work. My business cannot function without it. Please if you can help me as soon as possible it would be greatly appreciated. Kevin
  • 2072 Answers
SOURCE: Paper will not feed
What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
Clean them a few times, make sure they are dry then try again.
That may solve it completely, or your rollers may be slick and need replaced.
When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
Posted on Mar 01, 2008
  • 35 Answers
SOURCE: The paper tray has paper
WHAT MAKE AND MODEL? (HP?0
BUT WHAT THE PRELIMANARYLOOKS LIKE.
1 OF THE PROBLEMS IS THE PRINTER IS THE TRAY IS SET TO CUSTOM.
PULL TRAY OUT LOOK AT HOW THE TRAY IS SET ....
IT SHOULD BE IN STANDARD NOT CUSTOM.
AND ANOTHER PROBLEM ALSO IS THE TRAY'S ADJUSTMENT IS OPEN TOO FAR.(CLOSE IT UP TILL PAER IS HELD IN ON ALL FOUR SIDES.
Posted on Jun 09, 2008
SOURCE: printer message "paper empty custom in MP"
Its asking for you to put some paper in the tray at the side of the printer. There is a small hatch on the right hand side which will turn in to a paper tray when pulled open. Put in the paper and it will print. You will then have to disable that tray to prevent it happening again.
Posted on Dec 16, 2008
  • 1126 Answers
SOURCE: MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Posted on Aug 18, 2009
tim30921
  • 6 Answers
SOURCE: Printer starts to print but then stops
try cleaning the rubber roller that picks up the paper from the tray with aocohol
Posted on Jan 10, 2010
Testimonial: "it worked thanks"
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
Media tray empty
Printer is not sensing the papers.Try and re-load the papers a few times
Apr 24, 2014 | Brother Office Equipment & Supplies
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Paper Empty in Custom Tray message
there's something wrong with the paper sensor
Jul 23, 2009 | Samsung CLP-510 Laser Printer
Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    "490: MP tray is empty" message when trying to print labels from Word 2003
    The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
    Oct 18, 2008 | OKI C5500n Printer
    Not noticing paper
    I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
    Dec 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
    Samsung CLX-2160N All-In-One Printer Logo
    49 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
