Question about Boston Acoustics BA735 Computer Speakers
My subwoofer has a loose conection somewhere can it be fixed or can I get a new one?
  • 6,831 Answers
I will not say that it is certian that you will ned to buy a new one, first check it out, maybe we can help you to fix it yourself.
If the loos connection is at the speaker itself you can just open it up yourself and solder it again and it should be working fine once again.
If you are not familliar with this kind of technical work just take it to your nearest repair shop. The truth is that there is not much that could really go wrong with a speaker. But don't replace it untill you try to resolve the problem. It will be really cheap if it is only a loose connection or a blown capasitor. Please rate this.
Best regards
Posted on Sep 25, 2009
    President:
  • 1,653 Answers
Yes it can be fixed if you can get the case off!
The bass in my Sony 3-way 6X9 speakers wont work
if these speakers are several years old, chances are that the left one is just blown. could be a loose wire, but if not, it would be cheaper to get new speakers than to get that one fixed
Apr 05, 2012 | Sony 3-WAY 6X9 SPEAKERS Car Speaker
My battery run out of power, so i bought a new one to change, i disconnect and change the new one, may be after 2 hours, i re conect but the radia ask for security code. This beetle is from 2001 in...
Check the car manual. The code for the vehicle radio should be hand written somewhere in the back or on the radio information page. If no there, take the car to any local VW dealership and they will give you the code free of charge.
Jul 23, 2011 | Car Audio & Video
My emergence brake patol dont old when pressd
Loose conection somewhere. Line broken? Pedal loose?
Feb 03, 2010 | 1990 Chevrolet Lumina
My central locking stopped working and i cant get my petrol cap housing open to put petrol in to get it fixed! any ideas? any way of unlocking it manually? i have an audi a3 2001
On some cars you can unlock the door twice and this will release the petrol cap - otherwise you could check for a loose conection somewhere in the fuse box.
Aug 11, 2009 | Audi A3 Cars & Trucks
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Jul 15, 2009 | Wave Audio CS801 Speaker
1 subwoofer stopped working in a box for 2
Hello mccanello55,
You need to remove the subs from the box in order to check the internal box wiring. First, make sure that the wire going from the nonworking sub terminals to the enclosure terminals is OK. Then check the "braided" leads on the back of the terminals going to the speaker cone. If the wiring all looks OK, remove the wires from the sub terminals, and use a multimeter set to the lowest ohm range and check the resistance across the subs terminals. You should read somewhere between 3-4 ohms. If the meter reads infinity (that is no reading at all), then the voice coil is open. If it "pegs" (reads "0"), the coil is shorted.
Either open or shorted means the voice coil is no longer working.
I could not find any replacement parts on Sony's support page, so it's most likely that they don't even repair these. They probably just replace the sub if it's under warranty, and if it's not under warranty, they probably recommend that you buy a new one.
Hope this helps.
Apr 13, 2009 | Sony Xplod (P589) Car Subwoofer
Ashton home theater sub not making any noise
It sounds as if the amplifier for the subwoofer is shot. If the subwoofer has a seperate power cord from the rest of the unit, your amp is toast. If the subwoofer is powered by the same unit that is powering the other speakers it could be a loose connection somewhere.
Apr 02, 2009 | Audio Players & Recorders
When i plug in my subwoofer it has a constant hum
Sounds like you have a bad connection somewhere. Make sure all of your connections are secure. If theres anything that is a little loose you'll get that hum. You might also try replacing your cable too. If it became pinched somewhere it could cause that problem
-Captain Jake
Feb 11, 2009 | JBL PB10 Subwoofer
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
I have a Kenwood Subwoofer, SW-305, S/N 00901468, that when the power is one and hooked up there is a loud buzzing sound. No audio comes out of the subwoofer. I have checked and rechecked my conections and...
please try to replace your RCA plug that connects from your input player to your Kenwood Subwoofer..coz it not have open ground or has no continuety in it
Dec 05, 2008 | Audio Players & Recorders
Boston Acoustics BA735 Computer Speakers Logo
99 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
