Question about HP DeskJet 5550 InkJet Printer
Color printing is not possible - HP DeskJet 5550 InkJet Printer
Hp color laserjet cm2320
No. Color printer need ALL cartridges with ink to print.
Mar 27, 2014 | HP Laserjet CM2320nf All-In-One Color...
8560 will not print in color from Office 2010 programs such as Word and Powerpoint. Some photos will print in color. The 8560 is connected via Netgear router to a new (in March) Dell Inspiron running...
probably drivers have become corrupt it has nothing to do with office 2010.
first do a firmware update and then update the drivers that you use.
Find all of them here
Jul 18, 2011 | Xerox Phaser 8560DN Laser Printer
My color laserjet 2025 won't print color
If you print the demo page from the menus is that in color? If it is then it is possible that you have a black and white only printer driver installed or your driver is defaulted to black and white only. It is also possible that you have one color empty which stops color printing but often allows black and white printing to continue.
Mar 10, 2011 | HP Office Equipment & Supplies
I get color print, but why does it not print black?
Is it possible that when you inserted the Black cartridge, you forgot to remove the protective tape which covers the ink spout?
-a.
Apr 01, 2010 | Canon PIXMA iP90 Mobile Printer
Printer will not print colors
Printer not print colors. possible reasons....
  1. your color catridge may be empty.
  2. Your color Catridge may be jam.
  3. your color catridge may not be properly installed.
Thanks
Aug 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
No red color printing
Possible nozzle blockage, usually solved by physically squirting cleaning fluid into nozzle and letting soak for a while.
Printers are so cheap nowadays perhaps it might be worthwhile investing in something new!
May 27, 2009 | Office Equipment & Supplies
Printer won't print in color
I would guess that without specifics I would look at the printer settings. You may have the "print in grayscale" box checked thereby printing all colors in shades of black. I don't understand if you want to print in color or black and white by your question, but the solution addresses both possibilities.
Mar 22, 2009 | HP Office Equipment & Supplies
WHEN PRINTING THE COLOR IS VERY WEAK
You have to disassemble the printer and clean the prisms inside the black box within the printer. The prism for the red and yellow colors are near the bottom and face up, so they easily collect dust buildup, thereby causing weak or striped printing of these colors.
Mar 03, 2009 | HP LaserJet 2605DTN Color Printer
Hp 3210 photosmart Is it possible to print from black cartridge only,
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
Feb 20, 2009 | HP Photosmart 3210 All-In-One InkJet...
Probelms printing with black ink
On my system when I select print I can go to the print settings and I have the option of selecting either color or black. Not sure if that helps.
Feb 04, 2007 | Epson Stylus Photo 825 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
