Question about JVC RX-318 Receiver
Phono input is a moving coil the same as a mag pickup. can I use a mag pickup turntable with my JVC reciever
    Brigadier General:
  • 8,546 Answers
If you mean Moving Magnet vs Moving Coil, they are different.
MM is the higher output of the two types so most Phono Preamps can deal with them.
Not knowing the specific receiver model, a direct answer to your second query is not possible. I would guess - YES.
"Since the coils are much smaller than those in the MM cartridge, the MC cartridge generates a much smaller signal."
see this great article where that originates...
Posted on Apr 04, 2009
Jvc l-A31 turntable volume not very loud, is connected to a amp with phono inputs, wires are connected to the cartridge...
Hello Charles.
Maybe you use the wrong pickup system.
Normal Phono inputs are just for MM-Systems.
MC-System needs other Pre-Amp.
Some newer Amps have a switch (mostly near the Phono inp.) to select MM- or MC- system. (MM means Moving Magnet-Sys. and MC is Moving Coil-Sys)
Best Regrets Gue.
Apr 21, 2017 | JVC Computers & Internet
Can i connect a turntable to a JVC RX-5020VBK receiver?
With a bit of effort: This receiver has a variety of auxiliary or "line" level audio inputs (CD, VCR, etc.) but none designed for a phono cartridge input. You would need an external phono preamplifier in between the turntable output and one of the JVC inputs to have sufficient audio level. (Some newer turntables come equipped with such a preamp, but most do not.) They cost from $20 to $50 from a variety of suppliers (MCM, Parts-Express, etc.)
Dec 29, 2016 | JVC Audio Players & Recorders
How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John.
Nov 14, 2011 | Audio Players & Recorders
I am trying to connect my Garrad sl 75 turntable to my Kenwood KC 105 amplifier, I connected the phono wires into the phono connectors on back of amplifier and the speakers i connected to output on back of...
If the player has a MD/MC pickup head, you need to use an input suitable for MD/MC
(Magneto Dynamic/Moving Coil). If that is not available, you need to buy a standalone
phono pre-amp (pre-amplifier with RIAA-correction curve). Like the TCC TC-400G/L.
Example: See HERE and some info HERE.
Oct 13, 2011 | Audio Players & Recorders
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
Is the Technics SL-10 turntable a pre-amped turntable?
No matter which cartridge you used on it you still needed a phono preamp.
"Due to the low output of the moving-coil cartridge, the SL-10 included a built-in, bypassable step-up preamp to allow it to connect to standard phono inputs."
Dec 25, 2010 | Audio Players & Recorders
Hi. Have a Yamaha HTR-5940 and want to put my turntable back into action, but can't seem to get the inputs right. Any solutions? Thanks John
You need a phono preamp and hook it to the aux input. Standard recievers don't have a phono i/p anymore - the phono i/p of older recievers used to have the phono i/p which included a preamp which amplifies the low signal level from the phono cartridge to a standard level. check here :
Sep 20, 2009 | Audio Players & Recorders
I have minimal volume coming from the turntable
You may need a phono preamp to increase your input voltage coming from the turntable. More information from you would be helpful like what kind of turntable are you using. Whate is your receiver/amp are you plugging into a phone input or a line input? Here's the science part: Typically a line level input is expecting a 2V signal. A Moving Magnet (MM) phono input would expect something in the mV range (e.g. 2 - 4 mV) and a Moving Coil input would expect 1/10th that of the MM input (so 0.2 - 0.4mV or thereabouts). If your receiver has a phonostage then you may have a different problem but this sounds like the phono is not putting out a voltage that the receiver/amp is able to amplify. Search for phono preamps (some are very inexpensive) but find out what type of cartrige your record player uses (MM,MC or crystal) all types have large differences in output signal voltage. Good-luck.
Apr 30, 2009 | Sony STR-DE598 Receiver
The electrical output from a turntable actually comes from the cartridge on the tone arm. Specifically, it's generated by an interaction between a magnet and a coil inside the cartridge. They come in two types, MC ("moving coil") and MM ("moving magnet") according to which of the two elements moves and which is fixed. MM cartridges produce more current but MC cartridges usually sound better. No matter which you have though, the total output is too low for the regular line inputs on amplifiers. Ten or twenty years ago, amps has special "phono" inputs. This would have a special pre-amplifier in it that would amplify the cartridge's singal to a level suitable for the rest of the amp. Most amps having a phono input only deal with MM cartridges, which have a higher signal.
I use an MC cartridge with an amp that doesn't have a phono input at all; therefore I needed to buy a special external phono pre-amp. I bought a Musical Fidelity X-LPS. But cheaper pre-amps do exist.
Apr 13, 2009 | Audio Players & Recorders
How to connect turntable Technics SL BD20 to marantz SR7000 amp
Most recievers should have Phono Jacks labled on the back. That is where my Turntable an (MCS made by Technics but was sold under the J. C. Penneys name) connects on my JVC. I have 2 JVC 's One is old (1972) and one is new. Both of them have Phono jacks. Phono stands for Phonograph. This is an old term for turntables. The jacks should accept RCA patch cords. Good luck.
Apr 21, 2008 | Audio Players & Recorders
JVC RX-318 Receiver Logo
117 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
