Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Getting "busy" display on all modes except no-flash mode...
As the title describes, I get a "busy" display when trying follow through on a picture in all modes execept non-flash mode (all the way on the bottom of the dial when turned clockwise). When I turn it on, select a mode and press the shutter button halfway to prep to take a picture, the flash opens up, I get autofocus and then I push the shutter button fully and I get a "busy" display. After awhile, it turns to 'err 99' display. What's your take on this?
Marc
  • 42 Answers
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
Posted on Mar 07, 2008
2 Suggested Answers
markevans
  • 148 Answers
SOURCE: "busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
Posted on Dec 23, 2007
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
Hello, my Canon 1000d wont take the picture at night just flash a bunch of times. It also says busy on the screen. what does this mean and how do you stop it from doing this?
This sounds like a flash configuration issue combined with the continuous shooting mode, which will take 3 pictures in rapid succession and display "busy" while the flash is recycling. For starters, switch it back to single shot mode. That's the button that looks like the stack of pages and the timer clock. Then turn off the flash. That's the icon with the flash lightning image with the bar through it.
You will probably need to adjust your ISO, shutter speed, and aperture setting to get a good low-light shot.
Hope this helps!
Mar 02, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
My Canon Sd1000 will not take pictures. You can
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera does not have shutter priority mode (Tv) as listed in the link. Instead, put the camera in manual mode and turn off the flash, and also turn off the LCD display (press the DISP button). With these settings, try the fix in a darkened room, opening the battery door immediately after taking the picture. Give it several tries, if no luck consider also trying step 5a described in the link.
Dec 29, 2009 | Canon PowerShot SD1000 Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
My canon Rebel XTi keeps flashing busy and won't let me take a picture
I just called Canon because I was having the same problem. They suggested putting the camera in the sports mode. The reason it flashes busy is because there is a buffer period after taking pictures where the camera needs to store the information to the disk or if using a flash, then the flash needs to recharge. If you have plenty of natural light, then the full auto (the green square) mode can be selected because the flash won't have to recharge. If you are using the portait mode, then you will have to wait for the buffer period for the flash to recharge and the information to be stored to the disk.
Jul 21, 2008 | Cameras
good luck.
mark
Dec 16, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Flash
the left tab.
■ When the menu is not displayed on the LCD
( ) button.
● Selecting the flash mode
mode with the exception of MOVIE CLIP mode.
LCD monitor.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Pentax 43WR LCD shutoff problem
With the camera on and in picture taking mode, hit the OK button. This button cycles the display through a number of modes, including one that is normally off (except when using the menu or view).
Sep 08, 2005 | Pentax Optio 43WR Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
759 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
