Question about Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case
Hi there.i have a problem.hope you guys can help me asap.when i switch my driver on the blue led light comes on....and as soon as i plug it into my laptop the blue led starts flashing and my laptop doesnt pick it up...all my important work files are on it...what to do..........please help me
  • 19,396 Answers
Try a replacement USB cable first, and test the external disk on a different computer, to ensure the fault is on the external storage unit.
Try also unplugging computer power cord for ten minutes, and restarting. If you use a laptop also remove battery to drain power. Disconnect as well Hard disk power adapter , and restart everything connecting the disk to a different USB.
Also test the disk on a different computer to ensure it is not the computer USB.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
There are two possibilities:
The USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. The model you indicated is SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty (physical damage).
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
The controller board inside the external disk caddy is faulty.
In this case the disk may be removed from caddy and mounted on a different SATA enclosure.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, just ensure it is SATA 3.5 inch (2.5 is laptop HDD ).
Posted on Sep 25, 2009
I have problem with remote control, my remote control gives me blue light to switch the dashboard on but there is no lights coming on the dashboard. what is the problem
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Mar 09, 2015 | 2006 Tata Indica LSi
BA falcon starting issue
sounds like you need a dealer to assist you with this some vehicles when the battery is removed the computer needs to relearn all functions .
Oct 31, 2017 | 1999 Honda Accord
Hi my tv had an overheating smell and now all i have is the blue led light and nothing else it is a phillips 37 PFL
Sorry to give you bad news....
The power supply has failed. If it is under warranty, take it back ASAP.
If you can get a refund, I recommend steering away from plasma technology. LCD with LED backlighting is the most reliable.
If you can only get an exchange, hopefully the next one will last longer.
Feb 05, 2011 | Philips 37PFL5322 TV
Fridge light takes 2.5 sec to come on
Hi!!!
Have you cleaned the switch actuator? It is usually located on the door frame since it is activated by the door. Some times accidental spills will keep the switch from working correctly.
Good Luck
Mar 11, 2010 | Refrigerators
Is there a way to shut off blue light
Hi my name is Eric,
I hope I can help you with your issue ,
Yes you can turn off the annoying blue power light, go into the menu and look for the item called blue eye effect on/off
Press the MENU button.
Press the ▲ or ▼ button to select “Setup”, then press
the ENTER button.
2 Press the ▲ or ▼ button to select “Blue Eye”, then press
the ENTER button.
3 Press the ▲ or ▼ button to select “Off” or “On”, then
press the ENTER button.
• Off : LED(Blue) will not come on when you turn the TV
on and off.
• On : LED(Blue) will come on when you turn the TV
on and off.
4 Press the EXIT button to exit.
If you feel good about my solution please click accept.
If you have more questions you can still respond,
I will reply asap
Thanks
Eric
Sep 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
InFocus LP650 will not come on
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
WHY DOES THE DISC PORT ON MY WII NOT GLOW BLUE ??
the blue light on the disc port of the wii has a connector inside.you need to open the wii first and check if the connector is in place.if not just plug it in.is the wii modded?if so,maybe the guy that fix the chip forget to insert the plug.or if its not modded then the LED is already burn out and needs a replacement.hope this one helps
Dec 24, 2008 | Video Game Consoles & Games
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case Logo
301 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Willem.
Willem.
Piyal Perera
Piyal Perera
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
