Question about Kenmore 19001
Card reader connection
Where or how do I get the serial port on my R/W 19000 Easy Import to recongnize a USB port?????
  • Czimm Dec 19, 2007
    I purchase the kenmore r/w 19000 2 years ago, I received a box with no instructions, card or cable. Then I ordered the cable. Should there also be a connection for power? No software cam with it so how do you get it installed?
    Cathy
  • drazil Jan 29, 2008
    Cathy,
    you should have gotten everything when you ordered it. It should have a power cord connector and software is really important to get it installed. I finally got my working had to use a differant computer than I planned on (installed onto my old, old computer, because of USB port problem). Hope you get yours going, it really is nice once it works.
    Drazuk
Buy a USB to Serial Adapter. I bought one made by IOGEAR and have had not problems,
http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Posted on Jan 13, 2008
Can I convert a Kenmore Elite reader/writer 19000 to USB?
Not unless it was USB to start with you can't "convert"
Oct 30, 2017 | Kenmore Sewing Machines
Kenmore 19000 Scan Driver
Did you install the driver for your scanner?
Jan 21, 2008 | Kenmore 19001
Will my PED BASIC work with windows 10
There is a version of the Brother PED-Basic that will work with Windows 10. Go to http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hf_basiceus , and accept the EULA. This is a free update.
However, check if your sewing machine will work with Windows 10. The list is here: http://support.brother.com/g/s/hf/os/windows10/win10_hsm_us.html . With some sewing machines, no USB driver is available for Windows 10. For these, you need to put the designs on a USB flash drive to import them on the sewing machine. For other machines, you may need to add a serial port card to the computer or get a USB to serial port converter to connect the card reader/writer. See https://www.amazon.com/Trendnet-TU-S9-USB-Serial-Converter/dp/B0007T27H8 for one model. (Note: you may need a different converter. The best converters have an option to change the pin assignments. A lot of older serial devices did not use the pin standard that was eventually developed.)
I hope this helps.
Oct 29, 2017 | Sewing Machines
We are trying to use a monogram wizard file wtih the singer quantum XL-6000. We have the image saved in a file but are not sure how to import to embroidery machine. Please help.
You must convert the Monogram Wizard file to a format that your XL 6000 can read. If you have the Singer Sew Ware Conversion Tool, you can do this by opening the conversion software and simply saving the file as an (note: Fixya thinks the "dot triple x" file format is profanity, but it's the main file format used for the XL-6000 so I had to type it out this way) or a .sew format. Once the file is in the correct format, you can then import it to the XL 6000. To import, you must have a special cable (serial port to USB) that has an FTDI chip in it. Only serial port to USB cables with the FTDI chip will work. Here is a link where you can purchase said cable: http://www.cablesalesusa.com/index.php?main_page=product_info&cPath=472&products_id=1968
After using the cable with FTDI chip to connect your computer to your XL 6000, you must then ensure the com port settings match. I am including below some links that may be helpful to you in figuring all this out. These documents were helpful to me when I was trying to figure out all this stuff for my XL 6000, and I hope they will also be helpful to you. Blessings to you and yours.
How to change the COM port for USB Serial adapter on Windows 7
How to configure the Singer Approved USB Adapter with Windows 7
I also have additional helpful files, but this site will not allow me to upload a file in .pdf format. If you would like to provide your email address, I would be happy to email the documents to you. One is a workbook for the XL 6000 (much more detailed than the Owner's Manual).
Here are two additional pages that might be helpful: trying-use#solution-section-lzldskb0i2jni14zl4eksues-1-3.jpg trying-use#solution-section-lzldskb0i2jni14zl4eksues-1-6.jpg
Aug 16, 2011 | Singer Quantum XL-6000 Computerized Sewing...
My Janome customizer 2000 will not write to the scan card. It says that it will not recognize the serial port.
Hi, I have the same problem with mine. Janome have not been very helpful. I didn't know if it was the card or the card reader/writer. I have a Janome CX500. Have you solved any of the problems?
Louise
May 14, 2010 | Janome Memory Craft 9000 Computerized...
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
Need a reader/writer or box converter for a Rose
It's a reader/writer box, however, the boxes (all brands pertaining to embroidery) use specially sized cards specific to embroidery programs. They don't work any differently than any other type of reader/writer or flash card, it's just that the generic brand cards will not fit.
The Box for the Rose (or any other Husqvarna) is hard to find because they don't make them anymore. Also, it requires a serial port instead of the new USB connection. Sometimes you can find them on Ebay. I don't know if anyone makes a serial port device with a USB adapter on the other end, but might be worth looking into.
I would suggest that you purchase one of the newer boxes that will read and convert any designs you may want to download from the net. There are a few . .
The Ultimate Box by Vicant which is also backward compatible to Win 98, which is what your Rose actually reads.
(There is also Magic Box, but I don't know anything about that one.) There's another one, also, but it only comes with a full embroidery program. $$$$
The only drawback is that it will not read any of your Husqvarna embroidery cards because they are code protected.
I have an Ultimate Box Plus with conversion feature and it works fine for me, very easy to use. If you get the box, make sure you get one that comes with the card and that it's an updated version.
Here's a link for information. I actually bought my box somewhere else cheaper, but this site is chocked full of information.
http://www.secretsof.com/content/2509
Hope this helps.
Apr 18, 2009 | Husqvarna Rose
New home computer.
Are you talking about the Embroidery Data Reader/Writer R/W 19000 that you can create embroidery designs off of your computer. If so I have one that has not been out of the box and I am willing to sell.
Sandy
Mar 17, 2009 | Kenmore 19001
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Sewing Machines Logo
217 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
