My Palm Centro says it has accepted the device, but the
My phone Palm Centro says it has accepted the device, but the car does not respond. It keeps cycling back to ''do you want to connect to a phone?'' then setup .
Hi my palm centro keeps over syncing over and over again. i would like to know how to fix it please.
Hello elmorenocali,
The hotsync information in the Centro User Guide is very thorough and is mainly in chapters 2, 10 and 12. I hope the user guide helps with the hotsync problem. Here is a download link for the Palm Centro User Guide:
http://www.palm.com/us/support/handbooks/centro/centrorow_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
May 08, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro keeps restartin and it will not go to the main screen
black palm centro screen how do i get it off the white screen havent droped it or got water in it, did it after the hard reset .could that of been the problem?
Mar 30, 2010 | AT&T Palm Centro Cell Phone - White
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Tried to lock my palm centro never gota question to set password just lock the device now cant get in my phone.
You may want to try a hard reset. Keep in mind you will lose all data in your phone. These steps restore the phone to factory settings
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the Palm2_bing.gif logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Dec 14, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
I cant use any other sim card on palm centro phone which is unlocked one. i can use airtel india with internet but others are not accepting internet connection
Every operator has its parametre for recieving data or GPRS and 3G (UMTS).Your phone is configured for airtel but if you want to use others their parameters must be entered separately and set as defaul correct one when changing SIM. To find parameters wisit other operators pages, there may be special numbers where you can call and recieve data messages containing parameters and simply save or find instructions how to manually enter them. Also you must activate WAP/GPRS function in every opearator and it winn need aditional charge.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My Centro started hot syncing itself.
try this: take the battery out, then hold down the red power button...keep holding it until you put the battery back in and your screen comes on. Hope this helps, it worked for my daughter's!
Jul 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My verizon wireless palm centro is unlocked but now it wont send or receive picture or video message! Any ideas on what to do?
have u contacted your new network provider?
they will enable MMS for you, (multimedia messaging)
they send you a txt and you accept/install then it should work.
pls let me know if all goes ok
Mar 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Centro GSM unresponsive at times
My Centro doesn't respond ("freeze") on incoming calls up to 10 times a day. The "answer" button (on the screen) and green "send" button (next to "phone") block and it is impossible to accept the incoming calls. It is necessary to perform a soft reset to solve the problem temporary. Even after hard reset the situation is the same. This is very frustrating for a new device. Sometimes, frequent callibration of the screen from the "Preferences" menue delays the freezing effect. AFAIK the problem is software-related, considering the recovery after reset. Is there any update on the palm support page / forums, related to the problem? I couldn't find any. From time to time, there is onother problem I experienced - from the contact menu it is difficult to dial the selected number. Sometimes it is necessary to press “dial” several times resulting in significant delay.
Mar 19, 2008 | Palm Treo 500 Centro
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
