Question about NRS Mibuka 6 Function 13 Range Analog Multimeter, DG668
My multimeter wont work what do i do - NRS Mibuka 6 Function 13 Range Analog Multimeter, DG668
  • 148 Answers
Check the internal fuse for possible failure
Posted on Sep 26, 2009
Why wont my cell phone charge
How many times has the battery been charged. Test the voltage of the battery with a multimeter as batteries do have a user life. While you have the multimeter, test the output voltage of your charger to confirm that it is working.
Jun 05, 2015 | LG Optimus L90 D415 T-Mobi4G Android...
My one camera wont work anymore
Check camera charger output voltage with multimeter. If there is no problem with charger; charge camera battery to full charge. As a next step; check your camera battery voltage with multimeter. If battery is dead, replace battery with new one.
Nov 17, 2014 | Uniden Wireless Video Security Camera...
Stopped working
Although you may think your battery can live forever, batteries almost never tell you when they stop working.
If you charged the battery, checked the contact on the battery and in the camera. (They should be clean and shiny) the only suspect in my eyes is the battery.
If you have a multimeter you could try to measure the voltage. It should be just above the voltage printed on the battery. If it says 3.7 volt on the battery, your multimeter should show at least 3.8, because the battery does not have to deliver any current, when on the multimeter.
Always when you have a strange error with your camera, switch it off, remove the battery and charge it. When you replace the battery and the error comes back, you should consult a service centre.
Jan 22, 2014 | Nikon Coolpix S4000 Digital Camera
My cordless phone wont charge
Take out the plug of charger adapter and hook a multimeter to check if your charger is working or not. Output voltage is mostly mentioned on the charger and it should tally with the reading on multimeter.
May 14, 2013 | Motorola Mobility MD4260-2 Twin Cordless...
Car keeps flatening batterry light and indorcators wont work either
battery may be flat. You can check that with a multimeter.
Next check the alternator. Faulty alternator leads to uncharged battery.
Sep 11, 2012 | 2001 Alfa Romeo 147
Washer wont start
You need to check the lid switch, you can test it's function with a multimeter to see if it is working correctly or not.
Mar 12, 2012 | GE GTWN5050MWS Washer
My acer aspire r1600 wont turn on
takeout the battery and insert it back,turn on the laptop with an adapter inserted in the power jack and power on the laptop.if it still wont turn then then check the adapter with a multimeter whether it working.if the adapter is working then it a short circuit on the motherboard.
Sep 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
The blades wont enguage i put a new switch sitll wont work
Hi, check the seat switch for continuity with a multimeter, its most likely not working. If ok check that you have battery voltage at the pto plug, if so the pto is no good. Hope this helps, regards Phil.
Jun 19, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
My drivers side window wont roll down and my power locks arent working at all
if the power locks don't work the windows wont work either. it's an electrical problem. you'll need to get a multimeter and see if the wires are geetting any juice. if they aren't you either need new wire or a new silonoid.
Feb 25, 2010 | 2005 Chevrolet Colorado
Laptop wont power up
Sounds like the next logical culprit to check would be the surface mount DC jack on the MoBo edge. They are a common fault on laptops/notebooks. You are working in the right direction in my opinion, so cracking open the Puter is next. If you have excellent soldering skills you could flow solder to correct any possible cold/bad solder points and/or use a multimeter to Ohm out points.
Jul 12, 2008 | Acer Computers & Internet
NRS Mibuka 6 Function 13 Range Analog Multimeter, DG668 Logo
189 people viewed this question
Top NRS Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a NRS Measuring Tool and Sensor Expert? Answer questions, earn points and help others
