Question about KitchenAid Dryers
How do you replace a band on a kitchenAid dryer
    President:
  • KitchenAid Master
  • 1,922 Answers
You remove the front cover,then top cover then re-string the belt around the motor pulley,drum, and the idler pulley, and manually rotate drum to align drum and put top and frt covers back in place
Posted on Sep 25, 2009
Kitchenaid Model Keys750GQ0 light come on and the timer running push the door switch light turn off check power fine at 220V Please help Thanks in advent
Unplug dryer and try bypassing the thermal fuse by taping the two wires together and plug back in and try to start. If starts replace thermal fuse.
Sep 21, 2011 | KitchenAid KEYS750LQ Electric Dryer
I have a KitchenAid Dryer - KGHSO2RMT2 Why does the door keep popping open during the drying cycle?
You need to replace the striker and catch. They are inexpensive and easy to replace. They commonly wear out on some models. Here is your part # AP3094183 All parts come with installation instructions.
www.appliancehelponline.com
Jun 29, 2010 | KitchenAid KGHS02R Gas Dryer
The dryer heats good but my whispering appliance now squels
The roller bearing on the belt's tensioner is at fault. Replacing the roller is the first step and also replace the belt too
May 13, 2010 | KitchenAid KEYS750LQ Electric Dryer
Kitchenaide dryer won't turn on. . .
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Aug 06, 2009 | KitchenAid Dryers
I am trying to find out how old my kitchenaid dryer is the model is YKEYE860WW2 Ser:9JH37361
I believe a Kitchenaid with a "J" in the second position of the serial number would have been manufactured in 1999.
Mar 18, 2009 | KitchenAid KAWS850L Dryer
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
KitchenAid K5SS Switch lever replacement
Remove the philips screw at the back of the head, and remove the name band. This exposes the 4 screws underneath. Unplug mixer. Remove the 4 screws and lift the top off of the head. Switch and motor are right there. Gently remove the 4 wire plugs, after marking them. Unscrew the 2 screws holding the switch down and lift out the switch.
Jan 18, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Open Questions:
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
