Question about ASUS M2NPV-VM Motherboard
Does not start up. Voltage of atx12 is ok. - ASUS M2NPV-VM Motherboard
  • 37 Answers
Have you tried reseating the CPU and Memory? Make sure only the minimum number of peripherals is present. Try it without any PCI cards.
Cheers,
Ripface.
Posted on Sep 25, 2009
Ingersoll Rand Part# 39875158, SG Intellisys Controller showing overdurrent when motor is ok
check if the voltage supply is ok or the tranformer on the panel is not giving over voltage
Sep 30, 2014 | Air Tools & Compressors
Why wont car start after charging battery its an au falcon
Check you battery connections. If they seem ok then get a volt meter and check voltage at the starter solinoid. If it is battery voltage then the small wire at the solinoid have a helper turn the key to start and you should have 9 to 12 volts. If this checks ok then you should have the starter checked. If no voltage the if is a automatic then check the nuteral safty switch. or ingnition switch.
Aug 15, 2014 | Cars & Trucks
Electric start wont work
Have you tested battery voltage? ideally looking for 12.5v min.
If voltage is ok next thing to check is the cranking voltage drop, if it's very low battery problem!
Jan 27, 2014 | Honda RX 50 Motorcycles
Pool heater wont ignite
see if gas on if ok voltage to both sides of pressure switch check to see if voltage to gas valve brown wire and ground or yellow wire, if voltage check ignitor if 78 ohms at 70 degrees ok if shorted or open replace also check fuses see if gas on if ok bad gas valve when starting
Aug 25, 2013 | Raypak Pool & Spa
I can not start my RM 2350 using in on 12v. Can someone give me the correct starting procedure please. Thanks
see if voltage to outlet if ok see if 12 volts to board input if ok then if no voltage going out of board bad board
Oct 07, 2012 | Dometic RM2852 Refrigerator
Battery light comes on. Had battery tested and it's OK.Checked battery voltage with key off 12.04 volts, started it voltage is 14.45. The light comes on after driving for awhile.
OK, sounds like a bad voltage regulator or loose belt. But, it's more likely a voltage regulator on the alternator that is not supplying enough voltage to the battery over time.
For maximum peace of mind, I would have the alternator replaced if you experience any starting problems attributable to a weak or undercharged battery.
14.45 volts doesn't sound bad to me, for an initial voltage, but there may be a problem with the alternator (like a bad diode trio) , which controls the battery charge light pretty directly.
Oct 28, 2010 | 2000 Ford Expedition
1996 oldsmobile eighty eight no start no power windows. Car stalled driving up hill. Fuses are ok, battery voltage is ok. Power windows did work before it stalled. Maybe a main relay could be the cause?...
How did you determine that the voltage is OK? Will it run the headlights, brakelights, and horn at the same time? It could have enough voltage without enough amperage(power). It could be a loose cable - that is what I would check first.
Feb 11, 2010 | 1996 Oldsmobile Eighty Eight
I think Power Supply does not worked then I was replaced it with the new but it still does not work, but when I released voltage of atx12, computer suddenly on and can not be stopped. Could you help me...
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU , and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck,
Mark
Oct 17, 2009 | ASUS M2NPV-VM Motherboard
2003 cadillac deville want start
check battery voltage, if battery voltage is ok, you may need to check fuses under hood on passengers side, if start fuse is ok, you may need to have your starter replaced
Aug 10, 2008 | 2003 Cadillac Deville
ASUS M2NPV-VM Motherboard Logo
179 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
