Question about Brother MFC 420CN All-In-One InkJet Printer
PRINTER SAYS NO CARTRIDGE CARTRIDGES HAVE BEEN CHANGED
PRINTER SAYS NO CARTRIDGE REINSTALL INK CARTRIDGE. I HAVE CHANGED THE BLACK, YELLOW, CYAN.i DO NOT KNOW WHAT TO DO.
PLEASE SOMEONE HELP ME?
  • 2 more comments
  • Anonymous Jan 02, 2008
    |Tried all of the above. Still the same message....no cartridge.
  • tegolf Jan 04, 2008
    PRINTER SAYS NO BLACK CARTRIDGE, but one does exist in the printer. I have replaced the cartridge, but the same error message appears.
    I have tried to perform a test print, alignment print, but the printer does not respond with any printing. It just keeps saying "NO BLACK CARTRIDGE"
  • Melomom Jan 06, 2008
    My printer says the colors need to be refilled and refuses to print even though there is color in the cartridges.
  • Azdesert54 Jan 09, 2008
    I changed all ink cartridges (all new ones). An error says to install cyan. I have installed cyan many times. Still the message persists. I have unplugged the printer and waited 5 minutes with the cartridges out. Then plugged the printer in, and closed the cover. Message "No Cartridges" appeared. I put the new cartridges back in, and it still says "Install cyan". What can I do to get this printer to work? I have never had any problems with the printer before.
  • 832 Answers
Unplug machine from power outlet. take all carts out. leave cover open. wait 5 min. plug machine to power and close cover. machine will demand carts. reinsert carts and answer question given on display.
If you still have trouble this might be due to the generic carts which have not the right construction. use original carts.
Posted on Dec 17, 2007
Cartridge Jammed in Canon MP520
Gently lift it out by pulling it toward you. Lift it up.
May 18, 2017 | Canon MP520 All-In-One InkJet Photo...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
http://en.wikipedia.org/wiki/Cyan
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Color
Recheck the placement of the ink cartridges. The black ink cartridge is larger; the cyan, magenta, yellow cartridges are all the same size.
When the ink cartridges were replaced, two or more may have been inadvertently switched or an extra yellow cartridge placed in.
Aug 04, 2008 | Canon BubbleJet i560 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
