Question about Home
Just moved into a condo with a whirpool tub. the
Just purchased a condo with a whirpool tub. the tub and condo are 2 years old and both have never been used or turned on. we filled the tub up and turned it on it makes a humming noise put no jets. Does it have to be primed if so what should i do thanks.
  • 54 Answers
Jets are in the closed position or the pump is shot.
Posted on Sep 26, 2009
GE Dryer possible control board problem
Get another one with a good name and sell your old one on eBay and get a good price for it.
Jan 12, 2015 | GE Dryers
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Just moved into a condo (about 14 years old). Has a programmable Noma Thermostat with no manual. We are having trouble figuring it out. Need help !! Thanks. Stan Plolnicky, Medicine Hat, Alberta
Did you find how to use your NOMA digital thermostat? I live in a condo with base heaters. Have three of those. They are less than one year old. When it got cold recently one of them went up to 34 degrees. I couldn't budge the numbers. It's caput. The second one I caught going up on a cold night this week so I solved the problem by shutting down the electrical box. The base heat came back. But without the manual I am working in the dark.
Pierrette in Ottawa Ontario.
Nov 22, 2010 | Kitchen Appliances - Others
We have a sub-zero refrig/freezer that came with our condo. Condo built in 1985. We purchased 12 years ago and were the 1st owners. This was originally the model and not lived in but very rarely by one of...
After 12 years you can expect that kind of repairs...I would not spend the 1200 for the compressor and would instaed replace the unit...it will just irritate you more from here on...
heatman101
Aug 30, 2010 | Kitchen Ranges
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Tub Access
Hi garyv47,
I'm Harvey the Master Plumber.
Your question is: Your daughter just purchased a new condo with an AquaLux whirlpool tub installed in the bathroom. The front side is removable for access to the mechanicals and is held in place on the lower side by velcro. When you pull the velcro loose the side begins to tilt up, but then stops as it hits the upper edge of the tub. You tried pulling down, but it appear to be held by something. You don't want to pull too hard and break something. Any ideas on how to remove it?
It has been my expirience that the top of these access panals are 'tongue and grove' type construction and are not connected to anything. Usually disconnecting the bottom and pulling the bottom out works. If you are concerned about breakage then it migt be wise to consider the Repair Directory to find a reparman. Or you could talk to the condo maintenance guy. You'll find these guys are a wealth of info.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 16, 2008 | Home
Ok final Question
If this is a frigidaire, when the washer has a load in it, as the agitator agitates the tub should move about 1/8 of a turn. Meaning that for 8 agitations the tub should make 1 revolution. We call this indexing in the appliance repair world. If the tub is making 1 revolution in 4 agatations or 1 revolution in 1 agitation, the transmission is bad. This should have a 5 year warranty if purchased before 2006. You will also need a tub seal. Hope this helps
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
Home Logo
135 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
