Question about Compaq Presario M2000 Notebook
Hi. I have a Dell Inspiron laptop. And I have
Hi. I have a Dell Inspiron laptop. And I have had it for about 3 month and now I have three vertical lines on the right part of my screen. Two are green and one is red. They are located about an inch apart. What should I do to fix it? Thanks.
    Novelist:
  • 110 Answers
You need to replace the LCD screen. Or use an external monitor 24/7.
sorry
Posted on Sep 25, 2009
I have a Dell Inspiron 1525 and when I turned it on this evening 1/3 of the screen is a series of vertical multi colored lines. Computer has not been dropped that I know of. And everything seems to be...
Hi.. Please run the Dell onscreen diagonostic test. If it completes successfully.. then its a problem with the video driver /any recent update made to the system. Just try to do a system restore if the test completes successfully.
Jun 01, 2011 | Dell Inspiron 1525 Notebook
My dell 9300 have line appear in monitor?
Hi three its a problem on the screen. Display damaged. If you use it another few month the line will be increasing. No way for repair. Only replacement is solution.
Jan 22, 2011 | Dell Inspiron 9300 Notebook
Hi.I.purchased.a.dell.inspiron.1545.laptop.6.months.ago.Unfortunately.the.spacebar.has.ceased.working.It.is.under.warranty,however,due.to.living.in.tasmania.I.am.unable.to.take.it.to.a.dell.servicer.in.per...
If you purchased it new, you should be able to get the keyboard replaced under warranty. Dell's come with a minimum 1-year warranty. Give them a call and tell them the issue with the spacebar.
Dec 20, 2010 | Dell Inspiron 1545 Notebook
Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Feb 26, 2010 | Dell Inspiron 6400 Notebook
Vertical lines on laptop screen
There are only two issues here, one it could be the data cable on the left side of the screen has come loose from the socket on the LCD.....most likely though is your starting to have a cascading screen failure and will need to replace the LCD panel.
Jan 05, 2010 | Dell Inspiron 9200 Notebook
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Laptop battery
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
regards
Mar 21, 2008 | Dell Inspiron 6400 Notebook
Compaq Presario M2000 Notebook Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
