Question about Packard Bell Computers & Internet
My 2414 won't start up ?help i press the power button the fan starts then with no sign of life.
  • 31 Answers
May be your battery is down
some case you need to recharge it
or other worst case scenario may be your laptop is dead
Posted on Sep 26, 2009
LG WM2277HB start button won't start cycle
Either the button is damaged or the switch it operates is malfunctioning.
Suggest you get a Technician to pop in and check it out while there is still plenty of life left in the machine!
Poppa
http://www.cdbaby.com/cd/poppamadison
Sep 23, 2012 | LG WM2277H Front Load Washer
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Wont come on!
Starting with the easy stuff: Try plugging in the power cord, but not the battery.
If that works, your battery is either dead, or the circuit for it is shorted out.
Are there any signs of life? When you press the power button, do you hear any fans? do see any lights?
Does the screen flicker? Your RAM may be dead if it does.
Oct 05, 2008 | Acer Aspire 5315 Notebook
My computer won't start! It was shut down by the start menu and when I went back to it about an hour later, I push the button in to power the computer on and nothing is happening. Yes, it is plugged in...
Unplug it and hold the power button in for up to 60 seconds to discharge.
Is there an I/O button in the back of the computer? Make sure it is set to I.
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
