There is also a small reset button on the outside of the head next to the brush that you can push to get it to start spinning again. dont know officially why its happens, but i would think its there as a safety switch in case something gets stuck
It could be the belt or there could be a large item stuck in the brush preventing it from turning.
1. turn the vacuum off and turn upside down to see if there are any objects stuck in the brushes and remove the object, then turn the vacuum over and turn it on to see if the brush spins, also sometime string and lint and other stringy type objects get rolled around the brush and the space between the brush and the housing that the brush is inserted into, you may have to get scissors and cut these stringy things in order for the brush to spin again.
If its the belt go to the vacuum cleaner companies website and put the model number in to get the correct belt for the machine. Do your homework because some belts can be purchased at walmart/homedepot much cheaper than ordering from the vacuum company and the shipping charges are ridiculous. Those belts are very easy to put on by taking the screws out of the bottom of the vacuum lift the brush up from the housing unit and take the old belt on ,slide the new belt on and make sure all the screws are put back in and voila.
I am a housewife and i have been doing this stuff almost twenty years.
The reset button did it for me. Thanks nyc2001
