Question about Lands Phones
I cant change the name on my toshiba business phone
How can I do this? I have tried any button combonation I can think of
  • 1 more comment
  • bbevis Sep 26, 2009
    The model number of the phone that I cant change the name on is the Toshiba Digital Business Telephone Model DKT3210-SD
  • Carl Navarro
    Carl Navarro May 11, 2010
    The button combinations need to be dialed from a phone with programming access. Each system is different, so you might want to post back with your system model number.
How do I forward my phone (DKT-2020-SD) to voicemail?
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Dec 08, 2010 | Toshiba DKT-2020-SD telephone
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
I am trying to change the name display on Toshiba DKT2020-SD... I tryed using #612, or intercom #621 I have no DN button... I get DATA PROGRAMED...but cant seem to do anything from this screen. I know I am...
You are on a CTX system and are using the wrong code. On most CTX systems this must be done through the Admin software which is dealer propriety...good luck
Nov 04, 2009 | Toshiba DKT-2020 Corded Phone
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
Aug 25, 2009 | Lands Phones
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Trying to change the name on the lcd screen and cant
to lock the key phone by key in the code followed by 4 ~ 6 digit password
Jan 29, 2009 | Toshiba DKT-2010 Corded Phone
Your Toshiba Name Change question of Apr 2008
Maybe I can help, Press ( DN ) + #621
Display changes to USER NAME ?
Enter new name
Press SPKR
1 - moves right
* - moves left
# - toggles between alpha mode / numeric mode
0 - scrolls the alpha / special characters
To blank out any portion of name press 1 ( in alpha mode ) and move cursor to thr right
Good Luck
Aug 05, 2008 | Toshiba DKT-2020 Corded Phone
Changing the names on extensions
Fuction
266344
Pw: 23646
Terninals & Sets
Show set: (type your extension in)
Your extenstion shows: Your Name or Name You want to Change
press top right Arrow button
Capabilities...
Bottom right Arrow button
Name:
CLR Change
Press Change, then use the keypad to type in new name
Prees bottom Arrow Button again, then Release button.
Sep 12, 2007 | NorStar T7316E Corded Phone
ME AGAIN
From extension 201: Press transfer then dial 104. Press the up arrow until the station number and name you wish to change is displayed. Press the hold key to delete the current data and enter the new name with the keypad by pressing the digit 2 one time for A, press the digit 2 two times for B and so forth. The volume up and down buttons will move the cursor left and right. Press the transfer key to store the new data.
May 16, 2007 | Samsung Phone PDCSLCD12B
Lands Phones Logo
141 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
