Question about Lexmark JetPrinter X1185 All-In-One InkJet
Scanner doesn't work
My scanner bar gets stuck and it makes a lot of noise. Doesn't scan. Can you help me?
    Problem Solver:
  • 8 Answers
Inproper connection between the scanner and the printer mainboard... Usually I'm changing the mainboard, sometimes the scanner assembly. Try to clean the contacts...
Posted on Dec 21, 2007
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
The scanner works fine but it doesn't automatically submit the info. Is there a setting somewhere that allows it to work this way?
scan "enable CR suffix" from your manual. You may also have to scan "enable LF suffix", but try it without first.
Oct 12, 2012 | Metrologic Instruments MS7120 ORBIT...
HP 4500...when trying to scan, or make a copy, screen displays "Scanner Failure" and will not work. Please help.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Sep 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
My hp jet scanner 6200c doesnt scan.
I lost the CD of the hp jst scanner 6200c, but i down loaded the program on line. However, when I scan nothing appears on the screen and the scanner makes a lot of noise. The light does go on on the scanner but it doesnt scan i get a blank
Nov 22, 2008 | HP ScanJet 6200C Flatbed Scanner
Epson v100 - stuck carriage
Check the guide bar that the scanning head rides on. Apply lithium grease to the guide bar. Make sure the gearing is not obstructed
Nov 03, 2008 | Epson Perfection V100 Flatbed Scanner
Umax Astra 1200S Scanner Problem
Open ur scanner ,s back body(its very easy)remove belt.. just clean scanner, s belt and dust from scanner with soft cloth..put it belt again..
Jul 05, 2008 | Umax Astra 1200S Flatbed Scanner
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Lexmark JetPrinter X1185 All-In-One InkJet Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
