Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 doesn't know when document is loaded
My printer does not recognize when I put in document in loader to scan/copy/fax. It just keeps saying to ''load document''. I hear no noises.
How is the printer suppose to recognize when the document is loaded ?
  • 390 Answers
SOURCE: blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Posted on Feb 14, 2008
IB4G2008
  • 3587 Answers
SOURCE: lexmark X4270 doesn't want to scan
sounds like your scan settings need a look..do you have the print manager installed?
Posted on May 03, 2008
SOURCE: lexmark x4270 all in one
try cleaning the scanner glass it might have dirt settled on it.Had a similiar problem solved by cleaning it.
Posted on Jul 09, 2008
  • 3940 Answers
SOURCE: lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Posted on Jul 14, 2008
SOURCE: Faxing using Lexmark 1290
quero um dowlod pra instalar no meu computador...
Posted on Oct 06, 2008
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
THE DOCUMENT WILL SCAN INTO THE SCANNER BUT WILL NOT COMMUNICATE WITH THE COMPUTER HOW CAB I GET IT TO GO TO THE COMPUTER?
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
Sep 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark x4270 can't connect message. what do I do?
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do i load paper?
A4, Letter, or legal-size paper can be loaded. The minimum size that can be loaded into the ADF is 3x5 in. When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper. When making copies, sending faxes or scanning, load your original document into the feeder, face down.
I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X4270 All-In-One InkJet Printer
There are black vertical lines going down the middle of the page whne i copy or scan and fax documents. What is the problem.
It could be due to some dirt on the scan lens on the printer. Refer to this article on How to Clean the Scan Lens and White Roller on the Lexmark X4250/ X4270/ F4270. I hope this helps.
If you need additional assistance. please contact Lexmark technical support so they can help you. thanks.
Nov 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK X4270 SCAN ONE PAGE NOT MULTI-PAGES
S:
Please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Also, let me know the error message while scanning the document.
Apr 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 doesn't want to scan
May 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
X4270 Printer
i had the same porblem and the nice people at lexmark told me how to fix it. First unplug your printer. second.. hold the stop/cancel button while you plug your printer back up..keep holding the stop/cancel button and you will see a message that says erasing memory. the fax, copy and scan lights should flash and only the fax light will be on. That should do it but you will have to put your personal information back in, like your speed dial numbers, etc.
Sep 18, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
