Question about Canon Pixma iP2600 Photo InkJet Printer
I cannot re-set the ink levels the tanks are
I cannot re-set the ink levels the tanks are full but register no or low ink no software downloads are compatible
SOURCE: Ink tanks are running low... BUT!
I am having the same problem (except with the Magenta tank) and I am beginning to think it is a hardware problem. I have tried all of the following: reset the printer cleared the memory reinstalled the tank reinstalled a tank I knew worked jebss32 perhaps we should start trying to deal directly with Canon.
Posted on Sep 17, 2007
SOURCE: Ink Level
The obvious solution is to buy Canon ink cartridges. If you don't care about an accurate readout, buy cheaper cartridges and swap the chips. I'd suggest keeping spares on hand and change them when one color stops printing.
Posted on Jan 16, 2008
SOURCE: PIXMA MP160 ink level reset
the ink absorber is full
canon pixma mp160
Posted on Apr 17, 2008
Arius
  • 446 Answers
SOURCE: IP4300
if you have been using this for sometime chances are you are getting a wrong indicator on your screen, sometimes it is not as accurate as supposedly. kindly check the number of prints you made before. i suspect that you are actually runing out on ink
and might need to replace the affected color.
Posted on Jul 28, 2008
  • 1335 Answers
SOURCE: Says ink tank level low when it is still half
This usually happens when you are using aftermarket inks. The sensors on the cartridges are not always up to specs. The problem does not occur on OEM cartridges.
Sometimes you can remove and reseat the same cartridge and the printer will resume. If the problem persists after trying the remove and reseat procedure, the cartridge should be replaced and the defective cartridge discarded.
If you are near an office supply that rebates for old cartridges and you are reloading your own cartridges, take the old cartridge in and replace it with an OEM cartridge so the problem doesn't repeat.
Hope this helps.
Posted on Aug 10, 2009
Ink indicator lights
It's mean "ink out". Not actually "inK", but ink level counter reached zero. If using original ink tank, just replace with new one. If using "hardware resetter", reset ink level counter. If using CIS ink tank, it will be auto reset.
Remember, it's program not actual ink. So, if you reset it, ink level will show full, even if you didn't refill ink tank.
Oct 01, 2013 | Epson Stylus C43SX InkJet Printer
How can i tell the ink levels in the cartridges
You are either low on ink or the yellow cartridge is blocked. If you have a plug in the cartridge, doing a print head cleaning may help. On my inkjet printer, there are two levels of print head cleaning available.
Which brand/model printer do you have? Accessing the print cartridge level depends on the model and usually the software that you have installed. However, the software-provided level is an estimated level and may not accurately reflect the actual ink level in each cartridge. This is only available if you install the full-featured software from the manufacturer.
Generally, to see the estimated levels, if you have the full software installed, open the printer Toolbox. Then find a tab related to Maintenance and then get the estimated ink levels. For my HP printer, there is a specific tab just for the ink levels. (If you use Windows, there may be a icon for the printer in the notification area (on the right with the date/time information) that will let you open the software. Right click on the icon to access specific parts of the program.)
My printer has an option to print a quality test page in the Maintenance section which gives a better look at the ink levels. (For my HP inkjet, this is under the Device Services tab. Print head cleaning is also accessed here.)
Some printers with an LCD panel will let you access these maintenance items directly from the printer.
Please add a comment with your printer for additional information.
I hope this helps.
Dec 27, 2011 | Office Equipment & Supplies
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Jul 11, 2008 | Epson RX595 Photo All-In-One Printer
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
New INK cartridges will not reset
download this software http://www.mediafire.com/?31yfdujziy0, it's a reseter of canon ink level
zouaier
Feb 02, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Brother 5440cn print ink level device will not show on pc
nice to know what your ink levels are isn't it But these gadgets no matter which make of printer are software glitches that do a compute on the numbers pages printed its not like a fuel gauge in you car with a float in the tank. So don't worry too much about it.
Apr 08, 2007 | Brother MFC-5440CN All-In-One InkJet...
Canon Pixma iP2600 Photo InkJet Printer Logo
73 people viewed this question
old marine
old marine
