Question about Motorola Mobility RAZR V3
  • 181 Answers
The volume control buttons on the left side of the main screen are probably stuck. Try fiddling with it until it comes loose and you should be all set.
Posted on Dec 18, 2007
How to turn off text clicking
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
The key pad on my Motorola V3s RAZAR doesn't work the only button that works is the power button. All the other buttons don't work, how can i fix it myself.
If you're going to do it alone,follow this steps.
1. try to check if the volume up or down is working,if not, remove the battery cover and dismantle the lower panel at the back using a T6 precision screw,unscrew 2 screws and by using your thumbnail look for edge cover,insert and lift it up gentle (remember that a flex connector is attach on the right side If done,check the volume switch and remove the circular metal (keypad membrane) that is volume high and low apparently.clean it and align it when returning back before assembling it(might some shortage or hang buttons that's why keys are not working).,also try to check if the flex connector or socket is clean as well as the board socket connector cause keypad function has the line with it.assemble it and try if its working.
2. If the method above fails,need to replace the keypad flex maybe to risky for you to do cause the keypad connector is connected at the upper flip panel.i maybe reliable if you continue and there's a chance to break the lcd cause upper portion is to hard to dismantle.better bring it a mobile service center for keypad flex replacement.
hope this simple solution helps.
Jun 19, 2011 | Motorola Mobility RAZR V3
Only One Button Works On My Motorola Razar
fone may need flashing or keypad changed
Aug 31, 2009 | Motorola Mobility RAZR V3
Motorola Razar
That means the your flash cable has damaged. You have to call Motorola and repair it. Some time ago I have the same problem with my D&G phone
Motorola Razr V3 Where is the volume control to hear better
when the call is in progress just press right or left arrow key of your keypad it will show the volume.thanks and take care of yourself
Apr 28, 2009 | Motorola Mobility RAZR V3
Some keys are not working-Motorola Razar V3i
motorola razar v3i, this mobile which sd max support? please tell me urgent.please..........
Jan 30, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Keypad having a mind of its own
change the keypad matting,go to certified technician.
Oct 30, 2008 | Motorola Mobility RAZR V3
Keypad not working
when this happens..plz switch off ur mobile..remove the battery and fix it back again
Happy the help
Have a nice day!
May 31, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
