Question about Kenmore 24032\24036 Top Load Washer
Lid switch on a 20802 kenmore washer
I need to replace the lid switch on a 20802 kenmore washer How do I remove the top of the washer to replace the lid switch
    President:
  • 1,776 Answers
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 25, 2009
Kenmore 22432 top load washer - how do i remove top to replace the lid switch
what are the 3 numerical digits before the period as in ( XXX.XXXXXXXX) the first 3 numbers tell you who produced it for kenmore,then i can tell you how its dis-assembled to replaced the lid switch
Mar 05, 2011 | Kenmore 24042 Top Load Washer
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
Wash cycle stops
This is a relativly simple solution... The washer probably wont spin either... Thanats due to a bad lid switch. Try replacing mthe lid switch and go from there.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
depends some modles have 2 clips under the front left and right you stick your putty knife in there and pull the console up, also there could be end caps get a screw driver and pop them off then there will be 2 screws remove them. Then some models have 2 screws directly behing the consol remove them pull consol forward and up. Once you have got the consol situated there are 2 copper brakets push down and out with your screw driver this will release the cabinet soyou can replace the lid switch
Dec 26, 2008 | Kenmore 22622 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Kenmore washer 24642300
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
353 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
