Question about HP DeskJet F4280 All In One Printer InkJet
HP4180 scanner worked fine before but now is ot working.
I have tried troubleshooting, check connections still won't scan
Help
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
SparkGap
  • 363 Answers
SOURCE: HP C6180 All-in-one
I had this before from a similar HP all in one. I discovered if the scan data was bigger than the PC physical free memory then this error would occur. It required a PC restart to get it going again. Try reducing the scan DPI and/or reduce the area scanned with the preview bounding box.
Posted on Sep 23, 2007
SOURCE: Refuses to Scan - All connections have been checked
i was lost my softer cd there fore please send me softer &dierver
Posted on Feb 14, 2008
bandana_gyrl
  • 181 Answers
SOURCE: scanner won't work but the printer does
Ok here is the answer you have all been waiting for - look on the CD that came with any HP printer for the mac and you will see that it is for 10.3.9 and 10.4. I bet you dollars to donuts you have the new 10.5 leopard software and you got the new printer for free from the apple store.
All is not lost - go to the hp website at www.hp.com and on the left side you will see a grey menu that says software and driver downloads click on it and type your product. The version right now is 9.7.1 once you get all the way through. DO NOT INSTALL THE HP INSTALLER FILE - it is the same as the CD.
Well on the off chance your using windows the same applies - delete the old software on your computer and follow the steps above. The version number you will need depends on what OS but just make sure it is the most recent and you should be fine.
Posted on Feb 28, 2008
IB4G2008
  • 3587 Answers
SOURCE: Scanner troubleshooting
most likely it's the printer drivers.
go here to get fresh ones, but you may wish to remove old version first.
Posted on May 10, 2008
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
My scanner used to work just fine, but suddenly it won't work anymore. It is plugged in and everything, but suddenly in Photoshop, the Xerox 7600 option under File > Import disappeared, and the WIA...
Have you tried an other USB cable??? have you tried a different USB port on the computer??? try the scanner on an other computer as well, does it have POWER???... eazy stepps to troubleshoot all types of devices is to first make sure the device has POWER, than concentrate on connectivity (cables, ports, etc...) than try it on an other computer, re-install drivers as well..., check for viruses also, when everything is clean and it still not working than replace the device... it's dead (send flowers) ha! just kidding!
Jul 23, 2011 | Xerox 7600 Flatbed Scanner
My scanner had been working fine for over 3 years. Then, with out warning I cannot Get to the scanner bed....scanner light does not go on. a box appears that says, " no camera found..connection invalid". I...
Somehow your scanning device has been set to camera instead of scanner.
Loginto scanning software
you will see, somewhere in the menu to select the scanning source.
Make sure scanner is selected instead of camera.
After doing this try to scan
Hope this will work for you.
luciana44
Dec 02, 2009 | Visioneer 4400 Flatbed Scanner
Can not scan
You will need to chk for the scanner drivers if they are installed properly in the scanners in the control panel.....but before scanning something try copying from the machine,it will help you to isolate the issue from a hardware issue.....if the drivers are there uninstall and reinstall the drivers from the device manager......also install the hp solution centre s/w from the cd that came with the printer.....
Jun 24, 2009 | HP Photosmart 4180 All-in-One Printer
Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to support.epson.com. Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
Goodluck.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
May 21, 2009 | Epson Perfection V200 Flatbed Scanner
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
HP DeskJet F4280 All In One Printer InkJet Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
