Question about Linksys WRT54G2 Wireless Router
When using xbox it does not see the wireless router. Any suggestions
  • 37 Answers
Does the XBox have a WLAN adapter? As far as I know XBox only has wired ethernet by default and you need to buy a wireless adapter for them.
Cheers,
Ripface.
Posted on Sep 25, 2009
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
Trying 2 get connected 2 the internet on the xbox 360
firstly are you using a cable to your wireless router or a wireless adapter from your xbox 360?
if you are using a wireless connection i suggest you first connect to the xbox using the wire provided with your xbox and connect it into your router,
hope this works, if not write back and il help you
good luck
Apr 20, 2010 | Microsoft Xbox 360 Elite Console - Black
How do i get web code for my wireless internet
The wep code is the security code for your wireless network. this is setting of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 11, 2010 | Actiontec Qwest Wireless USB Network...
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
Xbox live cannot connect to network
I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
Jun 30, 2009 | Linksys Wireless-G WRT54G Router
Xbox live connection keeps crashing.
problems usually happen, when the signal strength drops.
I,d suggest hard-wiring the 360 to the PC or router, for optimal performance.
Thankyou for using fixya.
Mike @ compurepair.
Jan 05, 2009 | Microsoft Xbox 360 Console
Xbox 360
You cannot use the netgear wi-fi adapter as the xbox 360 will not be able to detect it. I suggest buying the wi-fi adapter specifically manufactured for the xbox360
Nov 30, 2008 | Microsoft Wireless Network Adapter Xbox...
NetGear WGT624 Wireless router
Check the security settings in the router . try 192.168.0.1 in your browser and check the access/security. Alternately reset the modem using button on back next to Ariel and press for 5 secs. Your computer firewall may be a problem or there may be an address conflict with your other modem.
Jun 28, 2008 | NetGear WGT624 Wireless Router
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Linksys WRT54G2 Wireless Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
