Question about HP Color LaserJet 2600n Printer
Printer shows as disconnected in print server, reset de spool and works, how can i give a definite solution to this?
drichards
  • 87 Answers
SOURCE: Users cannot print to network printer
Definately try to ping it. If you can ping it, then your raw port, usually 9100 has probably been changed. Set the configuation to print LPR with a queue name of HP1. Access this by highlighting the printer, right clicking it, select properties, select port, and select configure port.
Also be sure that the IP address is correct.
Posted on Mar 04, 2008
SOURCE: hp4350 prints multiple copies when only 1 requested
I have seen some reports of this problem, but I don't know of a definite 'cure", Seems like you've tried the obvious stuff already. My question would be, are you using PCL 5e, or PCL6 driver? The PCL 5e is the most compatible driver, and I know I have had a few strange things happen on different models using the PCL 6. It could just be a glitch in the driver, but I'd try the 5e just the same....that's my 2 cents worth.
For simplicity, you can download it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=412146&lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&taskId=135
Please rate me if it helps :)
Posted on Mar 26, 2009
  • 22 Answers
SOURCE: printer problem
Cancel all print jobs because most likley you have an error in a print job so cancel them shut off your printer turn it on nd try to print again
BestWishes                  -SunShine-
Posted on Jul 04, 2009
SOURCE: my printer spool service is not running
just open task manager and click on new task
then type in spoolsv.exe
your spool service should start.
else open controlpanle and in administrative tasks open services.exe
then fron there right click on spoolsv.exe and start the service.
Posted on Jul 21, 2009
bhagyavichar
  • 414 Answers
SOURCE: 1.As I give print command the printer head takes
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Nov 06, 2009
I have a networked printer in my office. it has been working normally until recently where it takes no print command from any of the networked computers. If i disconnect the network cable, the test print...
Try this solution
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Mar 07, 2011 | HP Computers & Internet
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
I send a document to print but it does not print, howver if a request it to scan it does it what do I need to do? in one occassion it told me that it was not set to work in a USB port but indeed it is my...
Hi melocoton777,
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software, then unplug the usb cable. 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press. NOTE: IF YOU HAVE OTHER PRINTER INSTALLED ON THE COMPUTER DON'T RENAME THE W32X86 FOLDER. JUST PROCEED WITH RESTARTING WITH THE COMPUTER;
The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just send me an update if the issue would be same.
Oct 18, 2009 | Dell 922 All-In-One InkJet Printer
Spooled documents get deleted
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Epson LX-300+ II Matrix Printer
Having to reset (unplug) daily
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Oct 03, 2008 | D-Link DP 300U (DP-300U) Print Server
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Prints part of the page then restarts the print
One suggestions would be to update the firmware of the Netgear Wireless print server Download the firmware for your print server from Netgear's website http://kbserver.netgear.com/release_notes/d102781.asp Instructions for upgrade are on the site! you can also try changing the spool settings, Set it to Print directly to printer RightClick on the printer click on properties and click the advanced tab. Change the spool setting to print directly to printer!! If this doesn't work kindly let me know! regards, babb
May 11, 2007 | NetGear WIRELESS PRINT SERVER 54MBPS...
Spool locks
I had the same problem - to fix it, I disabled "Enable Bi-Directional Support" under the printer's properties (in windows, right click on the printer in "Printers and Faxes", go down to properties).
Worked like a charm.
Nov 08, 2005 | 3Com OfficeConnect Wireless...
HP Color LaserJet 2600n Printer Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
