Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
HP photosmart C4180 cartridge jam. Cartridges are jammed and do not move out of current position.
SOURCE: hp photosmart c4180 - phantom paper jam
Had the same problem done what phoffman43 had suggested and it worked perfectly.
Posted on Jul 04, 2008
kcmetal9901
  • 102 Answers
SOURCE: HP C4180 says carriage jam but no jam and tried everything
uninstall your printer and then reinstall
Posted on Oct 31, 2008
SOURCE: Carriage jam
There's a small locking mechanism that holds the carriage in it's home position. This needs to be slightly sprayed with WD-40 or a similar lubrication (small amount). Problem solved.
Posted on Dec 30, 2008
  • 72 Answers
SOURCE: My HP Photosmart C7200 has an error message that
'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' Error Message Displays on the Control Panel
YOU CAN ALSO GO TO THE FOLLOWING LINK:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&lc=en&dlc=en&cc=us&lang=en&product=3382185
Have a good day,
Posted on Jun 25, 2009
don_farr
  • 1011 Answers
SOURCE: How do you reset the ink levels on HP Photosmart
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
Cartridge jam: tried all the suggested solutions; but still jammed. What to do?
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
Feb 08, 2011 | HP Photosmart C5580 All-In-One InkJet...
Brought the photosmart C4180 in the U.K. ,now living in Australia ,new compatable cartridges show an error message when installed
Just try to remove and reinsert the cartridges. You might also wanna clean the printheads with a damp lint free cloth. And See what happens.
You can also try this Link, it might be helpful. Finding and Installing Cartridges after Moving to Another Country
Feb 03, 2011 | HP Photosmart C4180 All-In-One InkJet...
I have just replaced my black ink cartridge and it shows allingment failed and my colour cartdige is low
Hi Paul,
I too have a C4180, and am getting Carriage Jam messages. I believe my problem to not be paper jams, but instead glob of ink that have collected under the cleaning mechanism on the right side of the printer. If you look inside you may find the same problem. There are (felt-type) absorbers and mine are soaked with ink, and the also some globs. There is a plastic tray that moves back and forth to clean the ink cartridges and it is no longer moving freely due to the ink.
I am trying to find a service manual to be able to disassemble and clean up properly the dripped ink. In the meantime I have used qtips, paper towwels and alcohol to try to remove the bulk of it.
Try this and let me know if it works for you.
Mike
Jan 25, 2011 | HP PhotoSmart C4180 All-in-One Color...
C4180 shows 12345 on a orange
this is cartridge error. pls .. check carrige assyembly....or cartridge
Apr 06, 2010 | HP Photosmart C4180 All-In-One InkJet...
Incorrect Cartridge Print cartridge in right stall not supported?
I changed the cartridge and it now works. I resent this though because it had been merrily printing before it decided it would stop and I have had to waste a three quarters full cartridge! I just hope the new one does not go the same way
Apr 08, 2009 | HP PhotoSmart C4180 All-in-One Color...
HP C4180 Carriage Jam
Try the steps mentioned in the link Bellow:
Also make sure you should Unplug the power cord when there is
still power in the unit, take out both the ink cartridges and apply little more pressure and move the carriage too and fro untill you feel it is moving freely (Dont worry it wil not break)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00806599&dlc=en&product=1141647
Good Luck
May 07, 2008 | HP PhotoSmart C4180 All-in-One Color...
hi,
i think you are getting a false paper jam.
> try this.
> unplug the power chord from the printer
> open the rear access door
> check whether there is any paper or any bit of paper stuck inside
> if so remove it
> if not, clean the rollers
> now plug the power chord
> check whether you are getting the message
> if you are getting try below
> open the front door so that you will get full access to the cartridges
> now move the cartridges manually from right to left several times
> check again
> if still you are having the problem
> service the unit
Mar 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
Seeker5211
Seeker5211
