Question about iiyama ProLite H481S (Black) 19 inch LCD Monitor
Hello, my iiyama routinely displays the Contrast menu and won't go away. I can click the Exit button on the monitor which only temporarily removes it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
15sunnybank, Did you try swapping it to a different PC to make sure that the problem is in the monitor and NOT in your PC? Sometimes when the DC voltages (which power up the electronic circuits in these LCD displays) become marginal due to age of unit, then weird stuff like unexpected/uncalled images/menu's could appear. First have a TECH type friend verify if all dc voltages are within specification. One more thing!! Don't post here without letting us know some history on the unit you hope to get help with. Age of unit?? Approx total # of "on" hours??
What happens if you put a 10 inch fan blowing cool air into the monitor?
I'm louie12fix on fixya or lmistyrel @aol.com Bye for now
Posted on Sep 25, 2009
I cant click on the brightness option in on the iiyama monitor with id nr E2282HD
If you are configuring the menu option displayed on the monitor itself, there is no control clicking any options with the mouse cursor. You have to adjust the brightness settings touching the buttons on the monitor it self.
Sep 18, 2016 | iiyama Computers & Internet
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Apr 12, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Feb 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor display
Hi again,
Appreciate the direct "Ask Me".
A suggestion, to verify if the buttons are the culprit/faulty, why not temporarily removed them or whichever is erring or cover the contacts with paper or tape. If problem is gone, verified that it is the button; if problem persists, then it is the logic controller (D/A) converter.
Nov 17, 2008 | Computers & Internet
Iiyama Pro Lite E485S
do exactly this:
- power off monitor with the POWER button!
- unplug power cord
- hold -/+ and keep holding them when briefly pressing POWER to get the monitor back on
- press menu
You are now in the service menu. Adjust the settings as you like.
- press EXIT
- power off monitor with button
- power on monitor with button
- AUTO SETUP... will be performed
- re-adjust brightness/contrast
Done!
edwin (rdam nl)
Apr 16, 2008 | iiyama Pro Lite 38a Monitor
Menu option
stuck in adjusting button?
Oct 11, 2007 | HP f1905 19" Flat Panel LCD Monitor
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
iiyama ProLite H481S (Black) 19 inch LCD Monitor Logo
205 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
