Question about MSI 649 Neo-V Motherboard
My system start's and after 60 seconds it's shotdown
    Sergeant:
    Novelist:
  • 183 Answers
Hello there undone_v2.
Here's your GEEK-steer ...
Although your problem could be caused by a few different things, it perfectly describes one of them: your CPU heatsink fan is out. In which case what is happening is that within the several moments after each startup, the CPU reaches, then exceeds its critical high temperature point that the motherboard (MB) is designed to monitor. The MB then dutifully (and thank-fully) performs an emergency shut-down in order to prevent the CPU from frying out.
== ACTIONS ==
Visually inspect that the CPU heatsink fan is working after you power on your system. If it's not, immediately power-down, then take steps to replace it.
However, if the fan is working, you still might want to check the CPU temp either from within your applicable BIOS display page (e.g., Hardware Monitor, PC Health, or similar sounding), or from within a possibly installed heat monitor applet found within your Start menu software items. If it is quickly reaching a critically high temp (this can vary anywhere from 65-90 Celsius depending upon your particular CPU type), then strongly consider freshly reseating the CPU to the heatsink since it's likely the necessary contact bond has been breached.
If it's neither 1 or 2, please follow up with description of the problem in greater detail, as it could also be your RAM or the MB itself.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Posted on Sep 25, 2009
  • 23 Answers
Hmm sounds like a faulty motherboard first if you know anything about the insides of a computer try unplugging the HDD the ram and the disk drives and if you have a floppy disc drive unplug that as well. basiclyunplug everything exept screen power supply keyboard and CPU if the problem carrys on it looks like youll need a new motherboard
Sony digital camera model 14.1 pix power is when start in second is shotdown
Can you please be more specific in your query, with more details ? Thank you
Oct 17, 2017 | Sony Cameras
No picture when i use camera then will appear the e32 error then shotdown
lens may be slightly experiencing a focus error . try cleaning the lens and contacts .
or set the switch to manual focus
Jan 27, 2014 | Cannon Cameras
Power suply is nomal but in few second shotdown
Please let me know the exact model no. of your unit. Observe the LED at the front panel if will blink a no. of times or has a pattern of blinks separated by the pause.
Dec 10, 2011 | Sony Televison & Video
My asus board p5s-mx se having problem when i boot my computer it has a message usb over temperature and in 15 seconds it will shotdown
Go into your BIOS settings and set your board to factory default.
Then you need to check and make sure all is working correctly inside case.
Nov 30, 2009 | Televison & Video
Usb device over current status detected shotdown in 15 second. cant acces the bios
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Oct 01, 2009 | ASUS P5PE-VM Motherboard
Laptop cursor not registering when pressed When the laptop is turned on,the cursor does not appear and nothing registers when I try to move the cursor around the screen to select something.
Ok on keyboard, press WINDOWS logo see start page comes up. using keypads arrow keys, access the control panel, find mouse, if you are using vista, set classic view. you may get around by tab key and up>down>rigth>left arrow keys.
Install driver again or use update \. come back start and shot down the computer by shotdown arrow, do not use brown button will not shotdown, it is stanby (On vista). Then turn on again see what you see>
If can not, Just use same system and reach out the system tools from accessories>system tools>Make defragmentation.
No result > make system restore. No result see tech.
JMC
Aug 15, 2009 | Dell INSPIRON 15 Notebook
Acer extensa will not boot to windows
What is happening when you press the power Button? Do you see any ligths, Any HDD moves? IF DOES.
TURN OFF by pressing and holding your finger on power button.
wait 60 sec. turn on and repeatedly press several times at F8 button.
If page opens on black and white, Use SAFE MODE.
wait til all line down. Then you will see windows opening in safe mode.
WHat ever you install last, remove, scan your computer for virus,spyware. when its finished, check your computer if need defragmentation. by Accessories>System Tools> Defragment.
If message comes such as windows will do this at schedule time or so.
Just turn off your computer using shotdown option (NOT BROWN BUTTON ON START) go to next arrow.
then turn on again see if windows comes back.
Goodluck
JMC
Aug 11, 2009 | Acer Extensa 4220-2148 Notebook
ACer Aspire 5100 Sudden Completly Shotdown by itself
Try using canned air and blow the dust out of the fan and all the vents.
Nov 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
AUTOMATIC SHOTDOWN
my computer is automatic shotdown in 15 min...what is the problem of my pc? all connection are connected and i'll checked the cards.and the settins are correct..what is the solution?
Jan 14, 2008 | Sharp VT-G21 21 in. TV/VCR Combo
MSI 649 Neo-V Motherboard Logo
77 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
