Question about IBM ThinkPad R40 2722 Notebook
I have an IBM R40- I bought it off of Craigslist and had very few problems until one day- I tried to start it but after the initial IBM main screen it goes to a black screen and briefly shows a couple of error messages. Its too fast to read all of them but one mentions a ''keyboard error'' and one of them says ''the system has been tampered with'' then goes to another black screen with a small icon that looks like a lock ( as if it is locking me out). I'm not sure if my wife did something to it or if it was dropped but it didn't come with any disks(I.E. backups)-please help!!-Steven-
    President:
  • 2,600 Answers
If you are unable to boot into safe mode by tapping F8 during the IBM splash screen then you will need a windows Install disc to boot off of and fix your boot command. If you don't have a disc then try to borrow a friends, you need to boot off that disc do that you can get to the recovery console and fix your boot menu.
Posted on Sep 25, 2009
    Sniper:
  • 67 Answers
Try starting in safe mode i think you have to press f8 during startup and then maybe you will be able to sort your problems out.
Posted on Jun 09, 2010
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
I bought a used IBM R40 whose hard drive failed. I tried installing someone else's XP Pro on my computer and then trying to use my license key from the bottom of my machine. It didn't work. I get the now...
must use an OEM install copy of the version on your key sticker. retail and upgrade versions will not work. i had the same problem with my r40. had to use e-donkey file sharing program to find it.
Aug 07, 2010 | IBM ThinkPad R40 2897 Notebook
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
Aug 31, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
I tried your advice, and I get a strange result
Try taking the hard rive and battery out, and see if it will get to the initial IBM screen, then let me know what happened.
Aug 14, 2008 | IBM ThinkPad R40 2722 Notebook
Hi vcan i ask you a question on a r40 problem
This could be a battery problem. Remove the battery and start on the power supply only. If this doesn't work, then check the power supply with an ohm meter to see if it's getting the proper output to the machine. If the supply checks good, then I'm afraid that you have a problem component on the motherboard, and will need to have it professionally diagnosed in order to track down the exact problem component.
Aug 13, 2008 | IBM ThinkPad R40 2722 Notebook
IBM R40 - 2897...not resonding
disconnect any power remove battery .remove mem and check the mem slots for dust and debris replace mem.remove hd check connections(hd pins)check connecter for dust.refit ;make sure properly housed.reboot,enter bios.reset to default.save settings and exit.pc should now restart.any indications of fault maybe mentioned at startup if not window should boot
Mar 04, 2008 | IBM ThinkPad R40 2897 Notebook
IBM ThinkPad R40 2722 Notebook Logo
191 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
