Question about Uniden Lands Phones
What numbers do I press to get voicemail on my Uniden phone?
How to set up voice mail so voice is clear
Posted on Jan 24, 2010
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
Aug 11, 2014 | Uniden DECT 6.0 Cordless Phone
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
No access #
Go to the menu/sel button and choose global setup. Choose edit voicemail and type in *123. Press menu/sel button again to confirm. Exit out and press your voicemail button on the bottom again. Done.
Apr 04, 2012 | Uniden D1660 Cordless Phone
Uniden D1660-2 how to set up voicemail and message
The Uniden D1660-2 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you subscribe to a voicemail system offered by your phone company, please contact them for instructions on accessing their voicemail system.
If you need a D1660-2 manual, you may download a copy here.
Mar 14, 2012 | Uniden D16602 Twin Cordless Phone
Trying to check the voicemail on phone. how do i do that?
If you mean the voicemail messages taken by your phone service provider when your line is busy, there are two ways normally used.
The first is to call your own number. When your message starts, press the "*" button. (Usually it's the star, but it might be different on your system. You might need to call your provider's customer service for details.) Then you're prompted for your passcode. Once in the voicemail system, voice prompts tell you which buttons to press to play messages, delete them and so on.
The second way requires you to dial a different phone number to get messages. You'll need to contact your service provider or check their website to find the access number for your telephone number if necessary.
Jun 03, 2011 | Uniden Cordless Phone
How do we retrieve messages from our home from another phone?
Dial the number of the other phone you want to get into the voicemail, when it stops ringing and it enters the voicemail, press * (star) twice. It will ask you for the password or mailbox number. I hope this helps
Mar 10, 2011 | Uniden Cell Phones
How do I check voicemail for a Uniden DECT 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
Access messages
call your home number...it will tell you if you set up voicemail...if you have not, then it will prompt you....after that...call you number from the phone, and it will say if you have msgs....do it from your cell or another phone? Call the number and when you hear your voicemail come on ....press th * (star) key...then you may have to have pass code...If you didnt make up one...it is always on the bottom of your phone!! Be sure to get it and keep in your purse!!
Jun 12, 2010 | Uniden 5.8GHz Dual Cordless Phone
How to change voicemail message. I have no manual. Thanks
I just looked up how to change it....press the mute button, the scroll left or right to reach recordpersonal message and press the menu key. when you're done recording press the 5 key to end it. Works for my Uniden DECT 6.0
Aug 12, 2009 | Uniden DECT 6.0 Cordless Phone ID
Lands Phones Logo
282 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
