Question about Whirlpool RBS245PD Electric Single Oven
Oven wont come on
Ran the cleaning cycle. After the cycle ended, the elements wont come on, everything works fine on display panel, also cant figure out how to get oven out of wall.
  • 1 more comment
  • ally jo Dec 20, 2007
    I cleaned my oven with the self clean option and now my oven doesn't work.  The burners work and the display panel is on but the oven does not heat.
  • bpowell857 Dec 18, 2008
    I run the self cleaning cycle and now the oven will not heat. Everything else works fine.
  • Anonymous May 14, 2009
    Tried pushing on the locking hook and still does not work.
    Sergeant:
    Champion:
  • 262 Answers
The oven door lock assembly has locked its self in to clean you can find the door lock assembly at the top of the oven where the door shuts sometimes if you push on the locking hook this will solve the problem
Posted on Jan 08, 2009
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Oven not heating KitchenAid KERC506HWH3
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
May 25, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Whirlpool RBS245PD Electric Single Oven Logo
307 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
